Enthusiast Joined Aug 16, '15 From Norway Currently Offline Reputation: 0 (0%) ![]() |
Hey, i have a problem with my car, when i stopp pressing the gas my car starts humping? Anyone know what is wrong?
Sorry bad english. Thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Has this problem gone on for a while? Or newly started?
I've noticed that the GT manual is very tricky, if you let off the gas too abruptly, it will jerk or "hump" forward and back a couple times. But if you let off the gas smoothly, it doesn't cause this issue. Not sure if this is what you're talking about or not though. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Sounds like you're lugging the motor. Should take it to about 2,500-3,000 before going into the next gear until you hit the speed limit and you can go straight to fifth. Coming to a stop unless you're needing engine braking just put it into neutral and use the brakes to bring it to a stop. Should eliminate any lugging.
Tanks it works just bougth car
Lo-Fi Version | Time is now: February 21st, 2025 - 10:12 AM |
