> Oil Sump plug not coming out
post Sep 1, 2015 - 10:09 PM
M4ddoX
Joined Jun 3, '13
From Auckland, New Zealand
Hey guys
Decided to change my oil and filter today. When I went to remove the sump plug I managed to get it going but it will not come out at all it is just spinning now. I have done some research and found its likely the nut inside the sump that has come undone so I was wondering if anyone has replaced the sump on a 3S-GE and is it a easy enough task. From first inspection it doesn't look that simple. Also any tips on maybe getting the sump plug out would be fantastic
1997 White ST202
post Sep 2, 2015 - 6:17 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
if the drain plug isnt coming out I would suggest taking off the pan and attacking the issue from the inside out.
the threads for the bolt seem like they may be gone
This post has been edited by Tigawoods: Sep 2, 2015 - 6:18 AM
エキサイティングカーレーシングチーム!
post Sep 3, 2015 - 12:57 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
there is no "nut" on the inside. its a thicker plate of material that is threaded for the plug. if the plug is spinning, you need to drop the oil pan and either replace it, or have it drilled and tapped for the next size up plug
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: February 20th, 2025 - 5:16 AM
