My RPM Level Keeps Sticking At High RPM |
Sep 2, 2015 - 10:23 PM |
Enthusiast Joined Jul 6, '15 From Texas Currently Offline Reputation: 0 (0%) |
I have a 1994 Celica GT and I recently had this problem. My RPMs will go really high while in neutral (or with clutch in while shifting) and I have to pull my gas pedal up with my foot. The first time this happened, which was a few days ago, I fixed it by just lifting up the gas pedal but now it stays at high RPMs. I am wondering if anyone else has had this problem or has any idea what it could be. I've already checked my throttle cable and it is not to tight, and I have cleaned my throttle body just in case it was sticking. Please, if anyone has any ideas as to why this is happening, comment.
Sep 3, 2015 - 12:29 AM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
I had a similar problem, i replaced the throttle pedal assembly and it went away
Sep 3, 2015 - 1:46 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Throttle cable is probably sticky. Or the throttle pedal needs a little lube.
Sep 3, 2015 - 2:53 AM |
Have someone get in the car and pump the pedal with the car off while you check out the cable and throttle body, has to be something catching or a spring binding.
Sep 3, 2015 - 8:29 AM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
Same problem right here I did a temp fix buy a throttle spring at advance auto parts orielys or autozone and use 2 zip ties to put it on place on the throttle adjust and enjoy and you need to replace the whole throttle by the way.
Lo-Fi Version | Time is now: November 24th, 2024 - 3:22 AM |
