mr2 inner axles rebuild., now the stupid dust cover wont go in |
Sep 3, 2015 - 12:47 PM |
like a normal day, to rebuild axle. the outer went swell. when i initially tested it, it was hard, and with a couple twists, now its smooth. needed grease to move around.
but the inner, wont budge, its stuck on straight. now i cannot even get the bearings out. any ideas? This post has been edited by njccmd2002: Oct 15, 2015 - 4:04 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 3, 2015 - 12:52 PM |
its upside down. I did this a few times myself.
Sep 3, 2015 - 12:54 PM |
what? the inner cage or the gear thats fixed in the axle
and now, i cant get it out!!! -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 3, 2015 - 1:37 PM |
got it out, need to figure out how to install...
Sep 3, 2015 - 1:41 PM |
Sep 3, 2015 - 8:17 PM |
Ha !
I was going to warn you about the axles. The balls and cage have to be right, it can be tough to get them aligned perfectly, but do-able. -------------------- |
Sep 3, 2015 - 8:42 PM |
if its not upside down, its just clocked wrong, rotate it about 10 degrees and try again.
Sep 3, 2015 - 8:45 PM |
the video above is one way to do it. I have the inner race still mounted on the axle. axle in a vice and I drop the cage and balls in together with the outter race. its a PITA
Sep 3, 2015 - 10:33 PM |
tell me about it. I quit for the day, i had to come to work, but no rush i have other issues with this swap.
Sep 4, 2015 - 8:47 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
When u rebuild those axles, ifs easier to leave the cage with the balls together and just clean it up and regresse it, seen it many times, where they rebuilt it, had same problem as u, then put it on a customers car, and drove it out, ripped the transmission case out lol, those axles r unbreakable
Sep 4, 2015 - 8:57 PM |
i got it in, and moves good, i literally followed the you tube tutorial, what a pain in the arse.
Sep 5, 2015 - 9:24 PM |
Lol it is what it is.
Sep 14, 2015 - 1:13 PM |
Enthusiast Joined Jan 9, '15 From Freeport, NY Currently Offline Reputation: 1 (100%) |
noob here, is this for the e153 lsd?
Oct 15, 2015 - 4:04 PM |
the stupid dust cover on the drivers side wont budge... any ideas
Oct 15, 2015 - 9:02 PM |
dust cover? for the axle? the ring that covers the axle seal on the trans? hit it with a hammer mang.
Oct 15, 2015 - 10:14 PM |
i had to figure out a safer way without bending it....
thats done, and this little bugger is the one that wont come out. usual sledge hammer 5 ponds and brass punch need this.. uggg, going to a local shop, maybe they can do it... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Oct 16, 2015 - 11:01 PM |
you and i were talking about 2 completely different things
Lo-Fi Version | Time is now: November 30th, 2024 - 9:40 PM |
