Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
tried googling and found little information, I recently purchased a front clip and while taking things apart, I found:
it suppose to be better tune, but how do you know what the setup are without a documentation of what they have tuned the ecu for....setting wise? im sure someone has a tom's ecu in their st205 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
I believe Rusty has the TOMs ecu in his 6gc. hit him up for some info.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
Yes that's correct I have a Tom's ecu. I think the only one here with a remapped ecu? No one had a mines or a blitz?
I tired messaging Tom's ages ago when I bought my ecu, but didn't get much of a response. I did however get a response from another company that did 'remapped' for the ST202/205 celicas in Japan. IMEC or ICode as they are now known as, stated.. 1 Ignition timing adjustment 2 Fuel increase in quantity. 3 speed limiter cut of 180km. There is also the possibility of a higher rev cut, and since yours is turbo'd I'd expect to see some boost changes. But it depends on what the customer wanted. These were fitted & custom tuned to each car (info off Tom's website) Usual fitted to vehicles with light modifications such as intake, exhaust, possible mild camshaft work etc. While these ecus may not give massive amounts of peak hp increases, it does clean up the entire rev range(increases across the full rev range) making it more responsive. Where I am from we don't have any sorts of emissions testing, but I did get mine AF ratio /exhaust o2 reading, he said these were impressive figures (would like to compare results with you USA guys) Would be interesting to see with a boost gauge, what is happening with boost. Great find btw ![]() -------------------- |
It will take some time before i find out what im actually dealing with....slowly going through this clip i found other parts such as a blitz boost witha greddy pro and the turbo being a blitz k1-380v .... im excited as this clip is the wrc version. Im planning to rebuild the long block and start a new that way i wont have much trouble knowing everything has been replaced, thanks for your reply.
Lo-Fi Version | Time is now: February 18th, 2025 - 4:11 AM |
