Enthusiast ![]() Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) ![]() |
If anyone will take the time to answer my multiple questions I'll highly appreciate it (:
1. I want to change the water pump and rings all around the timing belt in my 1994 Celica G.T Im going to buy this kit since the car will be open underneath is there anything else I might as well get replaced here's what's included in the kit btw it's all oem timing belt complete water pump assembly with housing timing belt tensioner timing belt idler timing belt tensioner spring valve cover gasket set four spark plug tube seals two accessory drive belts thermostat thermostat gasket front crankshaft seal camshaft seal oil pump seal oil pump o ring Oil pan gasket 2. My ac fan condensor went out and over heated my car but I caught it on time and did no damage is there anything I should replace oil , radiator flush or anything else I already swapped the condensor 3. When are the radiator fans suppose to turn on cause once I put the key in the ignition both fans automatically start 4. What are all the sensors that make up the cooling system 5. What's the best gasket sealer Again thanks a lot guys for the help |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
1. Looks like a good list, I recommend OEM parts for these, dont go cheap on felpro crap
2. change the oil, coolant should be ok 3. fans should come on at 200 degrees F. if they are coming on with the key on, check the AC pressure switch 4. water temp to the ECU and gauge are on the water neck. water temp for fans is on the bottom of radiator. 5. FIPG -------------------- 2001 Celica GT-S Turbo
1. Looks like a good list, I recommend OEM parts for these, dont go cheap on felpro crap 2. change the oil, coolant should be ok 3. fans should come on at 200 degrees F. if they are coming on with the key on, check the AC pressure switch 4. water temp to the ECU and gauge are on the water neck. water temp for fans is on the bottom of radiator. 5. FIPG Thanks a lot for the help 😁 |
Lo-Fi Version | Time is now: February 21st, 2025 - 3:19 PM |
