> Toyota 86 rims on 95 Celica?, will they fit?
post Nov 7, 2015 - 4:39 AM
Justin73
Joined Apr 9, '13
From ACT, Australia
My appologies for the simple question all, I'm looking to go to 16inch rims for my 95 Celica and was looking the the Toyota 86 rims. They look great but I'm lead to believe that they come in 16 inch but have a +48 offset? if this is the case, is it possible to put these on my car without too much work? I run King Springs (low) and my current wheels are 17inch with a +38 offset (close to struts but does not touch) they scrape a little when turning and you hit a bump, but otherwise they fit ok.
The offset will look to be a problem, will I have to get the guards rolled or put in spacers?
Cheers
J
This post has been edited by Justin73: Nov 7, 2015 - 4:40 AM
post Nov 7, 2015 - 1:33 PM
+48 offset. The rims will be sucked in more. Depends on tires you are running.
post Nov 7, 2015 - 4:41 PM
Justin73
Joined Apr 9, '13
From ACT, Australia
I intend to use a 205/50/16 tyre.
J
post Nov 7, 2015 - 10:17 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Justin73 @ Nov 7, 2015 - 1:41 PM) *
J
215/45/17 is best for the frs rims.
post Nov 8, 2015 - 12:00 AM
Justin73
Joined Apr 9, '13
From ACT, Australia
I currently run 235/45/17 so I'm thinking the 205/50/16 should fit without too much hassel.
post Nov 8, 2015 - 1:20 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (Justin73 @ Nov 8, 2015 - 1:00 AM) *
Ha you do realize fitting a 16" tire on a 17" rim more than likely won't work. A 235/45R17 will rub on front. Get the 215/45 like he said and lay your head to rest
post Nov 8, 2015 - 3:10 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
The tire will not fit. The rim is about 18" at the lip, and the tire won't fit over that. If it does, part of the bead will be overstretched and probably not seal. Not to mention it will not balance easily
QUOTE (BonzaiCelica @ Nov 8, 2015 - 2:20 PM) *
To run the gt86s wheels you need at least a 5-10mm spacer up front to clear the brake calipers which (at 10mm) is just barely enough to run the 235s. 225s will just barely clear as well with a 5mm spacer.
post Nov 9, 2015 - 12:29 AM
Justin73
Joined Apr 9, '13
From ACT, Australia
Thanks all, the wheels are off a Toyota 86 and the tyres on it are 205/50/16, so I figured that if I'm currently using the 17's with the 235 width, I believe the 16's should not give me too many hassles when fitting, unless I need spacers.
Cheers
J
QUOTE (BonzaiCelica @ Nov 9, 2015 - 5:20 AM) *
lol, soz Bonzai, I wasn't clear, I meant swapping the 17 wheels and tyres for 16 inch wheels and tyres smile.gif
post Nov 9, 2015 - 1:18 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
Stock FRS/86 wheels here are 17", did you get different ones there?
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Nov 9, 2015 - 4:03 AM
Justin73
Joined Apr 9, '13
From ACT, Australia
Yes Peg, the 86's here can have 16 or 17 inch wheels.
J
post Nov 9, 2015 - 6:35 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
86 base model 16's, and GT86/TRD86/etc 17's
Mike W
269awhp / 273ft-lbs
post Nov 9, 2015 - 7:33 AM
ILoveMySilly97
Joined Mar 8, '12
Pics of these rims? I'm curious to see how they look like. Lol.
post Nov 12, 2015 - 4:44 AM
Justin73
Joined Apr 9, '13
From ACT, Australia
Bugger, got a mate who bought a Toyota 86 with the 16inch wheels, after placing a wheel on the back and front, I can safely say for those who were after this wheel option for their 95 Celica, sorry but the 86 wheel will hit the front brake caliper, back is fine but no go on the front.
Cheers
J
This post has been edited by Justin73: Nov 12, 2015 - 7:07 PM
Lo-Fi Version Time is now: January 10th, 2025 - 10:49 PM
