exhaust pipping, safe or NOT-safe ??? |
Feb 18, 2004 - 11:47 AM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
I'm getting my exhaust piping done on Saturday. I went to the guy who's gonna do it for me, and we lifted the car to see exactly how "I" want the piping to run.
My thing is that i want the piping as straight as possible eliminating all those curves and turns. It's going to be a 3" piping and in order for it to be the way i want it, it would have to run under a lil section of the gas tank. So here's the question. Do you people think it's safe enough to run it under the tank like that or not. Or is there something that i can do to restrict so much heat under the tank that i can still run it that way? This post has been edited by sphinx_race911: Feb 18, 2004 - 11:48 AM |
Feb 18, 2004 - 12:49 PM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
So do you have the 3sgte swap? In your profile it says you do and it also says that you already have a 3" exhaust. You will want to run the piping with the groove under your car. There is a path already there. It is straight back, and then it turns by the gas tank and then goes over your rear passenger suspension. This is the only way you can run it. If you go anywhere else it will hit the ground an prolly break b/c it will be wedged against hte ground and car, or you will break something on your car. No it's not safe to run it under the tank.
Feb 18, 2004 - 1:39 PM |
yeah. I finished the swap about 2 months ago. I've been running my 2.5" exhaust piping for now. And i also know that there's a section where it's supposed to go arround the tank, but i was just wondering if i could eliminate that turn, and just go straight from there.
But if it's not safe enough under the tank, then i wont even try it. |
Feb 18, 2004 - 2:54 PM |
Who says the exhaust has to exit the rear... just stop it when you reach the tank... -------------------- "It's ok to be naked girl... I'm an artist!"
Feb 18, 2004 - 3:31 PM |
U'd probably want the fumes away from the cabin as much as possible...plus inspection will def. be looking for SOMETHING back there.
Make sure u still use the rubber connectors, as they are shock absorbers also. -------------------- |
Feb 18, 2004 - 8:45 PM |
Enthusiast Joined Apr 3, '03 From Omaha, Ne Currently Offline Reputation: 0 (0%) |
Its not the only way you can run it I have 2.5 in piping and mine does not go over the rear suspension. I don't know how they did it but I have only one bend in my cat back. and that is right off of the cat, it curves about 45 degress and goes straigh back to the stock muffler location. |
Feb 18, 2004 - 9:20 PM |
Enthusiast Joined Mar 6, '03 From South Central Los Angeles and Long Beach, CA Currently Offline Reputation: 1 (100%) |
Mine pretty much runs just like that. DOES NOT go over the rear suspension. It WONT fit, thats what my mechanic said. BUT yeah i only have 1 bend at about 45 degrees also.
David |
Feb 18, 2004 - 9:41 PM |
you have a lot of options when it come to running the pipping after the cat... you could make and L and have it goung out before the wheelwell .. as for going right over the gas tank i wouldn't do it be that just me... and i really don't know how safe that would be ... but just keep the pipe at least and inch and half away from anything that can get damaged by extream heat
Feb 19, 2004 - 6:10 PM |
Enthusiast Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) |
do you guys have it going under hte rear suspension or what ?
Feb 20, 2004 - 12:18 AM |
I have it going under the rear suspension. There shouldn't be any problem having it go under the rear suspension.
Lo-Fi Version | Time is now: January 10th, 2025 - 11:48 PM |
