> Oil pump seal replacement, Need some input
post Dec 6, 2015 - 4:43 PM
igpx12
Joined Jan 30, '14
From Cortland NY
Hello everyone, little bit of an issue.
My celi has the 7AFE in it, I have had an oil leak since I bought it and have diagnosed the issue. I had a worn out camshaft seal and looks like a worn out oil pump seal, the camshaft seal has been replaced, however I cannot remove the crankshaft seal as it seems to have seized onto the crankshaft end. I have tried prying at it, heating it and hitting it while heated with a hammer with no success in moving it. So anyone else had this issue? if so how did you remedy it?
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Dec 13, 2015 - 12:14 AM
igpx12
Joined Jan 30, '14
From Cortland NY
Finally managed to get the sprocket off and seal replaced, turned out to be corroded on to the crank and the end of the crankshaft had a burr on it. Hopefully nobody else has to deal with this, but if you do here is the end result of what I did. Drill, tap and pull.
post Dec 13, 2015 - 1:05 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Well that sounds like a whole load of fun!
Glad ya got it going.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:55 AM
