![]() Enthusiast ![]() ![]() Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) ![]() |
Hello I'm in the process of rebuilding the 1mz motor off a 1999 solara for my celica project and I was looking to replace the cams with 3mz cams and I was wondering if this would make a difference? I have herd 2mz cams work but I'm not sure what model Toyota that engine is in.
Thanks for your info and happy new year 2016!!! -------------------- |
Wikipedia can tell you a lot about what models have what engines. The 3MZ is a VVT engine so I'm not sure the cams will run correctly in a non VVT engine...?
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
yes you can put 3MZ exhaust cams in, however there are 2 versions, you want the early version. the tab on the cam for the position sensor will be in the right place.
yes you can use a 2MZ intake cam. its the 3MZ intake cam that has the VVT gear on it This post has been edited by Smaay: Jan 1, 2016 - 1:51 PM -------------------- 2001 Celica GT-S Turbo
Thanks smaay. The 2mz intake cam is on what model toyota? It looks like they were only available in Japan.
you are correct, the 2MZ is not a USDM engine.
https://en.wikipedia.org/wiki/Toyota_MZ_engine#2MZ-FE -------------------- 2001 Celica GT-S Turbo
Would just doing the exhaust side cam make a noticable differance?
yes, longer lift and duration, better overlap, higher top end.
since i put a 1MZ in my car to get it passed the BAR, i can tell a huge difference in the power band. the 3MZ had much more top end -------------------- 2001 Celica GT-S Turbo
Just looking at the cams I can defiantly see a big difference in the lift the exhaust cam is much smaller. I was reading up on the mr2oc forum and I see you posted about this. I was wondering if there is a certain year 3mz I would be best to pull these from. Also would I have to go with the 3mz valve lash clearance on the exhaust cam side? If there is a difference.
This post has been edited by doory100: Jan 3, 2016 - 8:28 PM -------------------- |
valve lash will be the same
What year would be the easiest 3mz to grab cams from that would work with a 1999 solara?
its posted in the MR2 forum
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:28 PM |
