> Feeler: mega squirt MSPNP 4th gen st215
post Jan 27, 2016 - 12:18 PM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
He everyone, I'm working with mega squirt in devolving a plug and play ecm for any of you running a 4th gen swap celica, It would be fully tune able just like there older 2nd and 3rd gen computer that they already offer.
They want to see if there is interest in this computer before they build it. So if you think you would be interested, Just msg here and let me know, I'll keep you all updated.
http://www.megasquirtpnp.com/docs/images/i...p2-mm9093_2.gif
post Jan 27, 2016 - 12:22 PM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
looks like i messed that up, Any one know how i can edit all that junk off of here?
post Jan 27, 2016 - 5:57 PM
Jmk91
Joined Jan 25, '15
From United States
You can edit your original post. Says edit quote and reply at the top right hand side of your post
This post has been edited by Jmk91: Jan 27, 2016 - 5:58 PM
post Jan 27, 2016 - 8:30 PM
richee3
Joined Jun 29, '08
From Denver
Edited, but you can try to add what you meant to post by hitting "edit post" like Jmk said. thumbsup.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 28, 2016 - 5:35 PM
TClifton91
Joined May 13, '14
From Savannah, GA
Very interested. Some more info and a price point would be helpful on deciding though.
post Jan 28, 2016 - 5:55 PM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
Here is a link example of a ecm already built for 3rd gen engines, so everything on this web link is on here of what things it can do
So for 4th gen the Pricing is $1199
http://www.diyautotune.com/catalog/megasqu...sgte-p-518.html
This post has been edited by toy8490: Jan 28, 2016 - 6:12 PM
post Jan 28, 2016 - 10:32 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (toy8490 @ Jan 28, 2016 - 5:55 PM) *
That's for the 2nd Gen 3sgte, not 3rd gen.
post Jan 28, 2016 - 10:49 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (toy8490 @ Jan 28, 2016 - 6:55 PM) *
So all that would be required is plugging in the st215 harness to the MS and then a tune?
If so I'm interested. Lol
post Jan 29, 2016 - 10:24 AM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
QUOTE (mkernz22 @ Jan 28, 2016 - 11:32 PM) *
This ecm is in development for creating to run 4th gen st215 ,
That link is only an example.
The link is so you can see all the things its able to do.
QUOTE (Noahwhite2014 @ Jan 28, 2016 - 11:49 PM) *
If you have a already running st215, then yes, Just plug yours in and tune away
But if you havent completed your swap, you would have to add a 4th plug that power the compter, Factory plug that would run the stock st215 ecm
post Jan 29, 2016 - 10:29 AM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
Fully Plug and Play Installation - No wiring required for basic functionality, other than adding an IAT sensor (included in the package). Install time is about an hour, only exception is if you need to have someone weld in your IAT sensor's bung for you real quick. That'll cost you just a few bucks at most tuner or welding shops.
3S-GTE base maps is pre-loaded to help your engine start on the first turn of the key (other model base maps included on CD)
Real time tuning and data logging with a laptop connection
Supports most aftermarket wideband sensors
16x16 Fuel Tables allow high resolution tuning
12x12 Ignition Tables
Multiple Acceleration enrichment strategies
Closed Loop Idle Speed Control
Air Conditioner Control
4 sequential fuel injector channels with individual trim tables
Onboard peak and hold drivers support both high and low impedance injectors - No external ballast resistor is needed!
Allows removal of stock mass air flow sensor
Advanced Feature Set (Included!)
12x12 Air Fuel Ratio Target Tables for use with wide band O2 sensor for precise tuning and table trim.
Built-in 2-step rev limiter / launch control with flat shift
Real time barometric correction
Internal 4-bar MAP sensor reads up to 44PSI of boost
Overboost protection
Closed loop boost control (Requires DIYAutoTune.com EBC solenoid kit, as the stock boost solenoid only works in an on/off fashion)
Knock sensor input with adjustable sensitivity
Headphone output for knock sensor - listen for knock while you tune!
Table switching input. Change fuel and spark maps on the fly for different fuels, nitrous activation, etc.
Input for flex fuel sensor - switch between E85 and gasoline on the fly!
CANBus connector allows interconnection of other MegaSquirt-compatible devices for additional functions (EGT Input, Automatic Transmission Controller, Additional Sensors.....the possibilities are limitless!
This post has been edited by toy8490: Jan 29, 2016 - 10:31 AM
post Jan 29, 2016 - 10:37 AM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
ok, i've got more update, this mega squirt is going to be the new Ms3 Pro, That means its the newest the latest, and the best that they have to offer.
post Jan 29, 2016 - 10:09 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (toy8490 @ Jan 29, 2016 - 10:24 AM) *
No, I understand. You said the link was for a 3rd gen ECM, when the link is for a 2nd gen ECM.
Just correcting you so people don't get confused.
Lo-Fi Version Time is now: November 25th, 2024 - 7:03 PM
