> Need help with camber problem
post Jan 30, 2016 - 11:17 PM
Fatdave115
Joined Jan 28, '16
From New Jersey
Hi guys im new here and am having problems with my camber after installing coilovers and lowering my car just need to know should i buy camber plates or if i can get away with putting camber bolts in and
post Jan 31, 2016 - 1:01 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I guess your coilovers dont have adjustable camber plates?
What brand/model coilovers did you get?
エキサイティングカーレーシングチーム!
post Jan 31, 2016 - 2:28 AM
Fatdave115
Joined Jan 28, '16
From New Jersey
QUOTE (Tigawoods @ Jan 31, 2016 - 2:01 AM) *
I think there megan there red not that that helps at all and no they arnt and im not sure how far out they are was debating buying a guage to check my self
post Jan 31, 2016 - 10:16 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
are you sure they are FULL coilovers? Because most all the coilovers offered for our cars have adjustable top mounts (i think the US Tein SS's are the only ones that dont)
Is the camber too much for you or uneven?
エキサイティングカーレーシングチーム!
post Jan 31, 2016 - 12:54 PM
Fatdave115
Joined Jan 28, '16
From New Jersey
QUOTE (Fatdave115 @ Jan 31, 2016 - 12:17 AM) *
Thought they were full coil overs i removed the struts and adjusted these to the height i wanted and put the assembly in and the tires are wearing unevenly i have a new rim tire combo i want to put on the car but need this alignment issue fixed first if i knew how to attach a pic from my gallery then i would post it so u could soo what i got
post Jan 31, 2016 - 11:25 PM
mkernz22
Joined May 10, '10
From MA
My guess is these:
http://www.ebay.com/itm/MEGAN-STREET-COILO...1f3&vxp=mtr
post Feb 1, 2016 - 7:17 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
those have top camber plates though
エキサイティングカーレーシングチーム!
post Feb 1, 2016 - 9:37 AM
Fatdave115
Joined Jan 28, '16
From New Jersey
QUOTE (mkernz22 @ Feb 1, 2016 - 12:25 AM) *
They look like these but no camber plates
post Feb 1, 2016 - 10:06 AM
cheela
Joined Feb 2, '07
From Berlin, WI
I believe only the front have the camber plates. the rears don't.
I have the blue EZ series which don't have them at all and just used a camber wedge kit on the rear. somewhat evened it out again.
post Feb 1, 2016 - 10:18 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I actually just realized that he never specified what end the camber issue was on.
so yeah, only ksport and I believe some BC's have rear camber adjustment.
Easiest solutions to adjsut rear camber:
Camber Bolts or Elongate the top strut hole.
エキサイティングカーレーシングチーム!
post Feb 1, 2016 - 3:55 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
any time you lower the car it changes the camber angle, requiring adjustable camber on the mounts. Unless you want to use shims but most people I've talked to don't recommend shims.
Bust a Deal; Face the Wheel.
post Feb 10, 2016 - 11:30 PM
Fatdave115
Joined Jan 28, '16
From New Jersey
Thx guys i think i found a bolt kit and a pillow top if im going to need it i just need to find out how far out it actually is b4 i buy anything
Lo-Fi Version Time is now: November 26th, 2024 - 10:45 PM
