> Identify These Gaskets / Seals, 7A-FE Edition!, Help me rebuild this engine. Please?
post Feb 1, 2016 - 9:09 AM
laughatthemall
Joined Feb 1, '16
From Buffalo, NY
I got a spare parts Celica with a 100k 7A-FE engine in it. It was running fine, but I figured I'd rebuild it over the winter -- both so I had a fresh engine to drop in when spring comes to replace my still-running 250k engine, and for the experience. I had the entire thing spec-checked, and everything is still within spec and doesn't look too worn at all (yay!) Got the head milled, cylinders very lightly honed, valve seals tested good, and everything cleaned up. So, I ordered the DNJ gasket set from RockAuto, and I have this mostly together. However, there are still some parts I just cannot figure out! Please see the linked photo for reference; sorry the image host turned it on its' side.
http://i.imgur.com/TA2nqsR.jpg
1.) ??
2.) Not sure, same size and same thickness as the distributor o-ring
3.) Not sure, flexible/no metal center
4.) Not sure, slightly larger than 5
5.) Not sure but I believe for fuel injector-fuel rail connection
6.) Not sure but I believe for fuel-injector tips
7.) Not sure, same style as exhaust camshaft oil seal (near the cam gears) but a bit smaller, has metal in it
Any help you can give would be greatly appreciated!
Edit: I don't know why this **** won't let me post any sort of reply, but here's an update.
Okay, so far we have:
1.) ! - Exhaust gaskets. Winner!
2.) ? - It looks just like the one on the distributor but a different color. I already put one on the distributor.
3.) ~ - Possibly thermostat gasket?
4.) ~ - I suspect somewhere on the fuel rail.
5.) ! - Must be on the injectors.
7.) ~ - Looks and built like the one that goes between the exhaust cam inside the engine and the exhaust cam sprocket; but a bit smaller. Update: It appears to fit right over the crank; I think it's an oil pump seal.
So, still need 2 and 7, possibly 4 and 3. Thanks for your help so far guys!
This post has been edited by laughatthemall: Feb 3, 2016 - 11:20 PM
post Feb 1, 2016 - 12:06 PM
jesse09
Joined Jan 19, '09
From Texas
2. I'm pretty sure it's the the distributor o-ring. I replaced mine the other day and it looked exactly like that.
6. Those look like the valve cover grommets. (Ignore the two arrows on the left)
post Feb 1, 2016 - 4:33 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
1.) Exhaust gaskets is what they kind of look like.
post Feb 3, 2016 - 10:37 PM
laughatthemall
Joined Feb 1, '16
From Buffalo, NY
7.) ? - Looks and built like the one that goes between the exhaust cam inside the engine and the exhaust cam sprocket; but a bit smaller.
post Feb 6, 2016 - 7:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
1 exhaust gaskets
2 distributor
3 thermostat
4 hhmmm could be for the dipstick tube
5 injectors
6 valve cover washers
7 cam seal
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: December 1st, 2024 - 1:55 PM
