need help wiring msd 8913 |
Feb 11, 2016 - 10:42 AM |
Enthusiast Joined Feb 5, '16 From Modesto Currently Offline Reputation: 0 (0%) |
Hello im new to 6gc and the beams world i recently swapped in a beams redtop and now as you may know i have no tach i purchased msd 8913 can it be wired to oem cluster i dont want an ugly tachometer on the outside. Any help is appreciated
Feb 11, 2016 - 2:28 PM |
Return the MSD tach adapter and use that money for a solder iron/solder and pack of resistors (10k of IIRC)
Follow the how-to (i forget its location) on what resistor to replace with the 10k OHM resistor. The results from using the resistor change will be much better than the MSD -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Feb 11, 2016 - 3:10 PM |
Return the MSD tach adapter and use that money for a solder iron/solder and pack of resistors (10k of IIRC) Follow the how-to (i forget its location) on what resistor to replace with the 10k OHM resistor. The results from using the resistor change will be much better than the MSD thanks for the reply is the tuorial here on 6gc |
Lo-Fi Version | Time is now: January 12th, 2025 - 1:39 PM |
