> Interior Plastics... PP?
post Feb 19, 2016 - 11:10 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Hey guys,
I just wanted to confirm, are a lot of the interior plastics actually polypropylene? I thought they were ABS and bought ABS epoxy (broke a tab off my tweeter cover) and that didn't bond whatsoever. Silly low surface energy plastics...
I think JBWeld Plastic Weld works for PP - has anyone ever used an epoxy that worked?
June '12 COTM
'95 AT200
post Feb 19, 2016 - 1:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
I used Permatex Plastic Weld to fix the lower left corner of the top center console piece where it had cracked all the way through.
2001 Miata LS 5-speed
post Feb 19, 2016 - 4:02 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Box @ Feb 19, 2016 - 11:58 AM) *
I used Permatex PermaPoxy and it did not bond at all after a 24h cure. Currently attempting with Loctite Plastic epoxy (though I noticed after applying that it shouldn't work on PP).
This post has been edited by HectortheRican: Feb 19, 2016 - 4:02 PM
June '12 COTM
'95 AT200
post Feb 19, 2016 - 4:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Feb 19, 2016 - 9:16 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (HectortheRican @ Feb 19, 2016 - 12:10 PM) *
Hey guys,
I used steelstik and just sanded it down smooth after. Never broke again. Even shaped new sections of plastic that chipped/broke off And sanded it down and painted to make it look just like the plastic too. Those haven't broke either smile.gif
post Feb 21, 2016 - 3:47 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Box @ Feb 19, 2016 - 2:12 PM) *
No, it isn't smile.gif The Loctite stuff didn't work... wonder if Home Depot will take it back lol
Thanks for the suggestion!
QUOTE (Noahwhite2014 @ Feb 19, 2016 - 7:16 PM) *
Steelstik, huh? I'll look into trying that.
June '12 COTM
'95 AT200
post Feb 21, 2016 - 4:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
Another thing that'll help is scuff the bonding edges with 200 grit sandpaper and then wipe the area with denatured alcohol before applying the epoxy. Which if you have the space to place and wrap it around the fractured joint you could use fiberglass mesh with a compatible epoxy, though not having had one with tweeters I imagine the tabs for the cover are fairly small.
post Feb 22, 2016 - 1:28 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Box @ Feb 21, 2016 - 2:21 PM) *
Very, very small. The most I could do is scuff and and clean. There isn't even space for my thumb and forefinger between the tweeter walls and the tab itself.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: January 12th, 2025 - 8:43 AM
