Control Arms from vert compatible with hatch? |
Feb 29, 2016 - 10:23 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Hey guys,
I can't remember if the rear control arms (the two pairs coming from the subframe - not the trailing arms) from the vert are compatible with the hatch. For that matter, are the trailing arms compatible? -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Mar 3, 2016 - 11:28 AM |
should be...
Mar 4, 2016 - 12:37 AM |
Use toyodiy to check part numbers.
Mar 4, 2016 - 12:56 PM |
Use toyodiy to check part numbers. I'm gonna have to go back to the yard and pull the VIN from that vert - it could have the sports package but I'm not sure. -------------------- taking too long to mod since '09
Mar 5, 2016 - 9:46 AM |
if the yard is close, and they have the return policy, bring them home, and if not usable, return them..
Mar 5, 2016 - 3:15 PM |
if the yard is close, and they have the return policy, bring them home, and if not usable, return them.. That's my plan. I already have the two pairs of rear arms (minus trailing arm), so I'll likely be returning them. The solid arms aren't the same part number and the toe-adjusting arms could be, depending on Sports Package. The trailing arms are the same between ST and GT, though. My question is if I use both pairs of GT arms... wouldn't I be ok? Since they're compatible with each other? I think I read something on here a while ago about the Polish bushings not fitting into the Sports Package arms, though. -------------------- taking too long to mod since '09
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:28 AM |
