> Airco installation
post Mar 29, 2016 - 7:50 PM
abflug
Joined Aug 22, '06
From Belgium
I'm planning to buy a donor car to take out the airco system and install it in my car.
Does anybody now if it's an easy job or is it difficult to reach all the parts for uninstallation/installation?
post Mar 30, 2016 - 7:25 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
ALL the parts? It's going to suck, need to pull the dash and then getting the lines routed around the engine with the engine in place is a pain.
post Apr 1, 2016 - 1:07 PM
abflug
Joined Aug 22, '06
From Belgium
QUOTE (Bitter @ Mar 30, 2016 - 8:25 PM) *
Ok thanks for the info
post Apr 2, 2016 - 11:34 AM
Bitter
Joined Mar 11, '06
Yea, there's probably not a good guide on the forum for this as I think air conditioning was standard in the US and most members are US members. The dash gets pulled for the evaporator core, that's probably one of the most time consuming parts of the job.
post Apr 5, 2016 - 11:58 PM
trdproven
Joined Aug 2, '05
From Guam
physical installation is not hard, the only thing you need to pull from the dash is only the glove box. I wrote at least the evaporator core sticky so that should help you with a big part of it. the rest inside the engine bay are just hoses, drier, compressor, condensor, etc.
You should buy a new evaporator if it looks busted, but if not, you should change the expansion valve and drier. then vacuum it, refill correctly and test for leaks. 3 months is a good period to know for sure if you have a leak, usually even slow leaks dont normally get past 3 months unnoticed. Good o-rings is another thing to look at and rechecking the oil on the compressor.
This post has been edited by trdproven: Apr 6, 2016 - 12:00 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 6, 2016 - 3:17 AM
the ac instalation may not be the hard part. the hard part is going to be the wiring. If your car is already prewired, great, otherwise, it will be a nightmare to rewire the whole car.
post Apr 6, 2016 - 2:08 PM
abflug
Joined Aug 22, '06
From Belgium
Probably I will go with an aftermarket installation to avoid old parts that are not in good condition anymore.
post Apr 13, 2016 - 6:25 PM
trdproven
Joined Aug 2, '05
From Guam
Is that the case too OP?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 13, 2016 - 11:55 PM
Bitter
Joined Mar 11, '06
I would assume the wiring is present but just not connected? Connectors taped to the harnesses?
Lo-Fi Version Time is now: February 23rd, 2025 - 8:02 PM
