2001 gts transmission problem, need to know what if any other auto trans will fit in my gts |
Apr 4, 2016 - 8:12 AM |
Enthusiast Joined Apr 4, '16 From Huntington wv Currently Offline Reputation: 0 (0%) |
Will a 2001 Solara trans fit and work in a 2001 gts?
Apr 5, 2016 - 6:12 AM |
Can't say for certain that it WONT fit, but I'd assume no. Better money would be spent on a manual trans Celica pedal box and associated bits and convert it to manual.
Cursory Google search took me to Wikipedia. U240E 4 Speed Automatic Transaxle Gear ratios for this transmission. 1st 2nd 3rd 4th Reverse Final 3.943 2.197 1.413 1.020 3.145 3.120 Applications: 2000–2005 Celica GT-S 2003 Matrix XRS (with VVTL-i engine) 2000–2006 runx/allex (with VVTL-i engine) 2000-2001 Avensis VVTI So probably your best bet is another Celica GTS. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 5, 2016 - 6:16 AM |
A541E is the model code for the 2001 Solara auto trans. Given the incompatibility of engine groups and trans groups I would say the answer is no it won't fit. The bellhousing probably doesn't even come close to matching.
Apr 5, 2016 - 11:43 AM |
Not only that but they're computer controlled by then so that'd throw another wrench into using anything other than the transmission original to the car. If you can drive a manual I'd convert it, from what I've heard it's the difference in the GT-S being quick or a total dog.
Apr 5, 2016 - 3:06 PM |
Enthusiast Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
Or if you can't drive a manual and don't want to convert you might just have to rebuild the current trans you have, or ge another car
Apr 5, 2016 - 5:41 PM |
I thought about mentioning rebuild what's there, but for what that'd cost and the value of an automatic 7GC would be better off buying another car.
Apr 5, 2016 - 6:19 PM |
Not only that but the electronic controls of the U240E built into the PCM will only work with the U240E. The U series transmission are a little different inside, not built like most other Toyota/Aisin automatics, more akin to a manual trans in how the gear sets are put together, all clutch packs and no drums/bands. Sadly only a U240E can replace a U240E exactly.
from what I've heard it's the difference in the GT-S being quick or a total dog. As slow as a 5spd GT -------------------- |
Apr 5, 2016 - 6:32 PM |
I thought about mentioning rebuild what's there, but for what that'd cost and the value of an automatic 7GC would be better off buying another car. I guess it depends on the situation. -------------------- |
Lo-Fi Version | Time is now: December 3rd, 2024 - 3:34 AM |
