> 3sge redtop vvt-i gauge cluster diagram, Swapped my 7afe engine out for the redtop beams vvt-i
post Apr 19, 2016 - 5:01 PM
Chrisss6g
Joined Apr 19, '16
From Kenner
Having trouble trying to figure out how my gauge cluster for my redtop swap suppose to be connected to my stock st gauge cluster . I need the gauge diagram if anyone knows it can you please let me know it would be a great help thanks
post Apr 20, 2016 - 8:55 AM
richee3
Joined Jun 29, '08
From Denver
Got your PM last night but didn't have time to respond. I need a little more info on your swap. If you are in the US (and assuming you have a 6th gen,) you only need a tach adapter to get the tach to work, and all the rest of your gauges will work with no modification. If you have swapped gauge clusters for the SS-III cluster, then everything will work besides the speedo if I remember correctly. The pinouts on the tach, temp, and fuel are all the same, but the signal to the tach from the Redtop is different, hence the need for the tach adapter (MSD 8920 or Dakota Digital SGI-8). Since none of your gauges work, there is an issue elsewhere in the wiring, but not at the gauge cluster.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: February 23rd, 2025 - 1:31 PM
