11 Pages V  < 1 2 3 4 5 > »
> Rise of the Phoenix, '96 Firebird Formula 6-speed
post Jun 27, 2016 - 7:55 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
The XV's are great if you like replacing bulbs every 3 months.
http://store.candlepower.com/
http://store.candlepower.com/64205.html
They say it'll play with stock wiring, but due to voltage drops you won't get the absolute most lumens with stock wiring, even with stock bulbs. It's worth it to run the harness it really is.
post Jun 27, 2016 - 2:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
Ye the other option being the Osram Night Breaker as far as not changing anything on the car, but I figured the Philips XV would be better since they only have the blue tint crap as a ring around the top of the bulb. Bulb life isn't that big of a deal since I try to limit my night time driving as much as possible, but when it starts getting dark at like 5:00 during the winter I don't have much choice.
I guess I could make a new harness, but I'll want to go all out and use like 10 AWG so if I ever feel like being a bastard I can use 130/100W bulbs. This is where having an ostentatious LS1 Firebird would come in handy as I could keep my low beams fairly civilized but go all out on the high beams, oh well the price of looking and sounding better has bit me in the ass already.
2001 Miata LS 5-speed
post Jun 27, 2016 - 7:23 PM
Bitter
Joined Mar 11, '06
the 100W bulbs aren't going to last very long either, they burn so hot that the filament gets very fragile. Make a harness even if you're using stock wattage stuff, it makes a big big difference. Big difference.
post Jun 27, 2016 - 8:10 PM
Box
Joined Feb 23, '12
From Warrior, AL
I guess I'll spend some time on Amazon and eBay finding some H4 plugs, relays, inline fuses, and some wiring. I need to go out and look at the car to see what's there and if there might be any constraints on wire AWG due to clearances with the popup assembly. Depending on differences in wire pricing will somewhat dictate what I use since I really wouldn't use 130/100W bulbs since I don't want to be a jerk. Yay more stuff to do.
post Jun 27, 2016 - 10:39 PM
Bitter
Joined Mar 11, '06
You don't need thick ass cable, even just bumping up to double the thickness of OEM makes a massive difference and is overkill. I think mine was using 12ga wire maybe 14ga, vs the stock 16 or 18ga stuff.
post Jun 27, 2016 - 11:29 PM
Box
Joined Feb 23, '12
From Warrior, AL
I was thinking 12-14 AWG after looking at thickness for given amperage and wire length charts.
post Jun 28, 2016 - 5:09 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just ordered the E-code lamps and some heavy duty H4 connectors, so that'll be a fun project once all that arrives. I need to look through my stash of wiring tonight to see what all I have before ordering wiring that I may already have. After doing some research over on LS1Tech the E-code conversion is the next best thing to a bi-xenon conversion, but is marginally easier and cheaper. So that's hope inspiring, it'll be nice to be able to drive at night and see. The Celica spoiled me with its headlight optics.
post Jun 28, 2016 - 8:02 PM
Bitter
Joined Mar 11, '06
More than marginally easier. WAY easier. Like nearly plug n play, if you can bake a cookie from a tub you can do the swap.
post Jun 28, 2016 - 9:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Someone had been making a "plug and play" bi-xenon kit, but it was $700 and I'm not sure if they're even making them anymore. I guess compared to putting one together it'll be considerably easier. Also I found something I want but will probably never be able to find:
I'd hate to know how rare, Euro taillights. The other day after a really bad thunderstorm I noticed some moisture in the driver side taillight. I thought about finding some '93-97 base model taillights and then covering them in vinyl tint so then it'd just be solid black. Other option is baking mine open, or however you go about separating them, and try to save them. Then could do the vinyl tint leaving the reflector exposed. Really that'll be my only option probably for them to look ok since the black grid section looks wonky after moisture got in...
post Jun 28, 2016 - 9:31 PM
Bitter
Joined Mar 11, '06
If the 98-02 tails didn't have the stupid honey comb on them they'd be nice. Can you remove that?
post Jun 28, 2016 - 10:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'm glad I'm not the only one that hates honeycombs, over on LS1Tech they're God's gift to automotive lighting... Apparently the '93-97 Formula/Trans Am lights are notorious for delaminating, so even if I found a nice set it'd just be a matter of time unless I could somehow reseal them and never let it become an issue. There's no way to remove the grid or honeycomb on the lights, but the '93-97 base lights would be sort of similar to having honeycombs removed and look like so:
Then they can be modified to look like such:
Even more reminiscent to the late second gen than the grid lights are.
post Jun 28, 2016 - 10:26 PM
Bitter
Joined Mar 11, '06
Not too bad, throw in some really bright LED plug n play bulbs and you're good to go I think.
post Jun 28, 2016 - 10:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yep, just have to find a set. My brother knows a guy at LKQ and had sent an email about getting a set, but haven't heard back yet. I do really like how they look on that blue T/A, would be even better on a black car I think.
post Jun 29, 2016 - 8:55 AM
cheela
Joined Feb 2, '07
From Berlin, WI
that last pic doesn't look too bad.
post Jun 29, 2016 - 5:01 PM
Box
Joined Feb 23, '12
From Warrior, AL
It's funny how big a difference some time and paint can make. I pulled the driver side tail light just now and it looks like whatever they used to seal the lense to the housing has dried up. I took some tint I had laying around and it kind of masks they "greying" of the grid where water got to it, so if I could stop these from leaking and holding condensation I'll be ok for the time being. Though I still want the base model lights to do the above mod or just black out, since I'd use vinyl tint I could always pull it off and do the mod once I'm tired of them being blacked out.
Oh and the way the lights are done there's a piece of plastic that covers the entire top of the seal and mating surface, otherwise some silicone would take care of it quickly and easily. Trying to find info now but the general consensus seems to be not to try opening them.
This post has been edited by Box: Jun 29, 2016 - 5:06 PM
post Jun 30, 2016 - 8:46 AM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
QUOTE (Box @ Jun 28, 2016 - 11:24 PM) *
The bottom one looks awesome!!!!
post Jun 30, 2016 - 9:27 AM
cheela
Joined Feb 2, '07
From Berlin, WI
post Jun 30, 2016 - 2:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
So after extensive research the solution to my problem was to drill holes in the bottom of each bulb housing, with much chagrin that's what was done. I think for the time being I'll throw some vinyl tint on them to hide the grid delaminating and wait for LKQ to find me a set of base lights to mod.
I hate the high rise spoiler though. You have no idea how happy having the Formula with a hardtop and the low rise spoiler has made me, that and the 6-speed but that's a given. The only thing I like about the Trans Am more is the rear bumper, depending on how hard it is to change them out I might have to look out for a nice black rear bumper to put on.
post Jun 30, 2016 - 4:00 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
QUOTE (ClevelandGaint @ Jun 30, 2016 - 9:46 AM) *
F-yeah,
Schwiiing!
Bust a Deal; Face the Wheel.
post Jun 30, 2016 - 4:38 PM
Box
Joined Feb 23, '12
From Warrior, AL
My brother really likes them too. I want a set of lights to mod so bad it's not even funny, LKQ guy needs to hurry it up. tongue.gif
This post has been edited by Box: Jun 30, 2016 - 4:39 PM
Lo-Fi Version Time is now: February 20th, 2025 - 12:11 PM
