> problem with guage lights, help me please!
post Feb 19, 2004 - 6:10 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
Ok, this afternoon i swapped my green lights to some amber LED guage lights, and now for some reason, parts of the tach, speedo, and such are MUCH brighter than other parts- particularily the 4 and 8 on the tach, 40 on the speedo, and the fuel guage seems to be really dim. how do i fix this- ive swapped lights at least 4 times now and have never ran into this problem before- help please! (ps the amber led's look great if it werent for this).....
post Feb 19, 2004 - 7:54 PM
The problem is probably that you're using LEDs. Try using regular bulbs, and the light should reflect much better. smile.gif
post Feb 20, 2004 - 7:46 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
wide angle led's or inverted led's might help if led's are what u want to use.
Team 6gc 2005
post Feb 20, 2004 - 12:42 PM
QUOTE (Drocay @ Feb 20, 2004 - 4:46 AM)
Have you tried them before? I've tried two different types of LEDs, and I've had troubles with both of them.
If you look at the rear of the gauge cluster, you can see that there are clear plastic prism sort of pieces that reflect the light. Using an LED bulb reflects light differently than a regular bulb, and that's what causes the problems. wink.gif
For comparison, here is my gauge cluster with LEDs:
Here it is with regular bulbs:
post Feb 20, 2004 - 1:46 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
No, but I was told they work better. I'm using Red Xenon 194's.
Team 6gc 2005
post Feb 20, 2004 - 4:08 PM
Shortty
Joined Jan 28, '04
From Mids
I'm using inverted LED's and while they are better than normal LED's they don't come close to the even brightness of bulbs
I've tried painting the bulbs with bulb laquer - but the colour was too greeny, and i've tried LED's, neither work properly. With LED's the light is good at some spots, and while you can see all of the dials light up - when you pass another car, and your night vision goes, then you can't see the duller bits.
Next plan, painting normal bulbs with normal blue paint! Let you know how it works, and how long the colour lasts for.
Shortty
This post has been edited by Shortty: Feb 20, 2004 - 4:09 PM
post Feb 20, 2004 - 8:38 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
just get normal bulbs with blue glass it will last the life of your bulb.
Team 6gc 2005
post Feb 21, 2004 - 1:03 AM
celicarocker
Joined Sep 25, '03
From cranston RI
QUOTE (Shortty @ Feb 20, 2004 - 4:08 PM)
i got bored and did that tonight actually.... came out ok, but i took them out for another coat of paint so it would be bluer... and i made my blinker lights red... wanted blue, but couldnt find any blue plastic around my house... ill change it eventually....
post Feb 21, 2004 - 1:18 PM
Shortty
Joined Jan 28, '04
From Mids
QUOTE (Drocay @ Feb 21, 2004 - 1:38 AM)
I live in the UK. BLue 194's dont exist!
post Feb 21, 2004 - 1:38 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
I know u can get some off the internet. If not locally.
Team 6gc 2005
Lo-Fi Version Time is now: November 24th, 2024 - 6:32 AM
