Oil filter relocation problems!!!, can't figure out what to do |
May 24, 2016 - 3:36 PM |
Enthusiast Joined Jul 12, '15 From Iowa Currently Offline Reputation: 1 (100%) |
hey everyone, so here is my situation:
I'm doing a turbo setup using the 3sgte turbo, manifold, and an aftermarket downpipe. the oil filter doesn't fit, so I'm trying to relocate. I have the moroso plate to attach to the block. (doesn't fit with factory oil cooler, have to attach directly to block). I have the trans dapt adapter for the oil filter to attach to. I was going to attach the factory oil cooler to that, then put on the oil filter, but the bolt for the oil cooler is too long in the trans dapt adapter..... so the options I see are: 1- ditch the factory oil cooler all together, and screw the oil filter right to the block.( not sure if that's a safe idea) 2- ditch the factory oil cooler and go with an air cooled oil cooler (radiator type). 3- try to figure out a way to still be able to use the factory oil cooler, (would prefer, but can't think of anything).. anyone have any suggestions?????? this has been holding me up, and driving me crazy. any help would be appreciated thanks |
May 25, 2016 - 8:13 AM |
Enthusiast Joined May 2, '16 From Tucson, AZ Currently Offline Reputation: 0 (0%) |
Option number one will work. back when i needed to replace my older 5sfe, the motor i bought did not have a factory oil cooler. it had the oil filter right to the block stock. granted i swapped my old oil cooler onto my new motor but you will be fine just to get it running. I would defiantly go with option two if you want long term reliability.
May 25, 2016 - 8:24 AM |
I used a Canton adapter and moved the filter to another location.
May 25, 2016 - 8:45 AM |
Clean the factory oil cooler and use it as paperweight! Then use option 2.
May 26, 2016 - 12:51 PM |
May 26, 2016 - 9:59 PM |
Enthusiast Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
Mine is an ST so I used a Thermostatic-controlled sandwich adapter and used an external oil cooler to ran the lines to the oil cooler. the Sandwich adapter opens at 181 degrees and sends the oil through the cooler. This way I add a little more oil to the system which helps with the oil temps. I used AN adapters and braided lines just like Smaay did.
Lo-Fi Version | Time is now: January 15th, 2025 - 12:23 AM |
