> celica st205 chargecooler system not working.
post Jun 11, 2016 - 8:43 AM
rhodesyboy
Joined Jun 11, '16
From lancashire
Hi I have recently bought a 1996 celica gt4 st205, I have noticed that once you sit on traffic for a while or at low speeds the engine light comes on and you loose a fair bit of power when you next floor it, I did the on board diagnostics and it was 'code 54' which is the charge cooler system, I then noticed the sensor is not plugged into anything and the wires that should go into the connector and up into the sensor are sort of braided together and stuffed into an electrical sleeve, I can only think that is to trick the ECU into thinking it is full? as it would get the voltage straight back? (not sure on how the sensor works). I then read a few instructions on checking the coolant level by taking the charge cooler cap off and revving it, the coolant level did not drop at all it just sort of wobbled from the vibrations so I'm also guessing the pump is broken or not getting a signal.
So does anybody know if that braided wire is a common bodge or if there is a reason behind it?
Or if anybody has any other insights to what the problem might be?
post Jun 12, 2016 - 8:19 AM
bridging the level sensor is a common thing, because even just a hair under a totally full intercooler will set code 54.
if you pull the LH side underplastic, you should be able to start the car, blip the throttle, then check for pump running. if not, its either dead or a wiring issue.
post Jun 12, 2016 - 9:19 AM
rhodesyboy
Joined Jun 11, '16
From lancashire
Ah ok cheers, how much of a blip will it be? Is it literally just a little poke or does it have to be held above 3000rpm or something like that
post Jun 14, 2016 - 8:31 PM
just a tap of the pedal should activate the system, it should stop the pump if the car idles for more tthan 30 seconds or somthing like that, i dont know the exact time, since mine has always been wired to run full time.
Lo-Fi Version Time is now: January 15th, 2025 - 7:32 AM
