> Engine rebuild running rough.
post Jul 17, 2016 - 4:09 PM
BondedBlowfish
Joined Jul 17, '16
From Idaho
Having a hard time getting this thing to run so I'm resorting to the help of others.
Just finished a 5sfe engine rebuild and I'm having a hard time getting her to run smooth. Almost sounds like timing issue, but I went through and rechecked everything I could think of. Engine idles and runs rough almost like running on three cylinders with the occasional backfire. I initially thought I got the timing off one tooth, but just rechecked and ruled that one out.
All timing marks line up on the crank and cam.
Internal cam gears in the head are lined up.
Coil checks out
New plug wires.
New cap and rotor.
New plug wires.
New plugs - Doesn't seem to be running rich or lean.
Completely rebuilt head with valves and springs
Webcam 294 grind.
All valves freshly shimmed.
Compression test checks about 160 across all four cylinders.
New fuel filter and injectors.
Can't find any vacuum leaks.
Checked to make sure all vacuum lines are routed correctly
I'm starting to loose my mind. Any help or ideas would be greatly appreciated.
post Jul 17, 2016 - 6:00 PM
Box
Joined Feb 23, '12
From Warrior, AL
Off the top of my head I'd check and inspect the MAP sensor, TPS, and IACV. Perhaps the engine coolant sensor for the ECU, but generally that's accompanied with running rich. Only other thing I can think of is the EGR valve being stuck open.
Just thought of something else, if it's OBDII you have a cam sensor which I'd check too.
This post has been edited by Box: Jul 17, 2016 - 6:04 PM
2001 Miata LS 5-speed
post Jul 17, 2016 - 6:28 PM
BondedBlowfish
Joined Jul 17, '16
From Idaho
I have another throttle body and EGR that I swapped over and it didn't seem to make any noticeable difference. I have a 94 celica which I don't think has the OBDII. I'll look into the MAP and temp sensor to see what I can find. Thanks for the info!
Lo-Fi Version Time is now: December 3rd, 2024 - 3:06 AM
