window molding part number? |
Jul 27, 2016 - 6:32 AM |
Enthusiast Joined Jun 10, '09 From South Korea Currently Offline Reputation: 5 (100%) |
i'm restoring exterior and need i found some diagrams but want to make sure if it is right one for my project. i have no idea if the quarter window assy. is actually a whole single part which includes glass and exterior molding. below is what i got from web search, but not sure if they are correct part names for my project. it's just 1. moulding, roof drip side finish 2. moulding assy, front door belt 3. window assy, quarter i appreciate for any input regarding this issue. thanks. This post has been edited by cellocinema: Sep 23, 2016 - 12:38 PM |
Jul 27, 2016 - 8:01 AM |
CHANNEL, ROOF DRIP, RH- 61261-20120
CHANNEL, ROOF DRIP, LH- 61262-20120 By door belt assembly, do you mean the weatherstrip along the bottom of the window? -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jul 27, 2016 - 10:08 AM |
CHANNEL, ROOF DRIP, RH- 61261-20120 CHANNEL, ROOF DRIP, LH- 61262-20120 By door belt assembly, do you mean the weatherstrip along the bottom of the window? thanks for your response. yes it's along the bottom of the window, but should be seen on the exterior like shown in the pic above. and what's the difference between roof drip channel & drip side finish which i found? ** i found a diagram regarding the part you mentioned, but it seems small(#61262 on the pic above). it doesn't go down all the way to the bottom of the window. i guess it might be something else that can contribute to dripping water from the roof? This post has been edited by cellocinema: Jul 27, 2016 - 11:05 AM |
Jul 27, 2016 - 2:21 PM |
On the door for the weather strip...
RH- 68170-20400 LH- 68220-20300 I don't see the front section of trim right now but I'll keep looking. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jul 27, 2016 - 7:45 PM |
On the door for the weather strip... RH- 68170-20400 LH- 68220-20300 I don't see the front section of trim right now but I'll keep looking. thanks for an update. it's always those little miscellaneous things that give me a headache when searching for parts. and also confusing diagram... * i'm a little concerned why it is described as 'inner' weatherstrip in the pic below...maybe it goes 'into' the panel? This post has been edited by cellocinema: Jul 27, 2016 - 8:14 PM |
Aug 3, 2016 - 12:27 AM |
alright, this is what i got now. a quarter window is actually a single part which includes side finish molding. let me know if you have some doubts.
1 6271020260 WINDOW ASSY(RH) 1' 6271020290 WINDOW ASSY(RH,COMPATIBLE) 2 6272020290 WINDOW ASSY(LH) 5 7555120520 ROOF DRIP SIDE FINISH(RH) *DISCONTINUED 6 7555220520 ROOF DRIP SIDE FINISH(LH) *DISCONTINUED This post has been edited by cellocinema: Sep 4, 2016 - 6:31 AM |
Sep 4, 2016 - 6:29 AM |
it turned out that #3&4 were not what i had been looking for. they are interior parts that hold the window glass. maybe its name is something 'finish' as in 'roof drip side finish'?
1 6271020260 WINDOW ASSY(RH) 1' 6271020290 WINDOW ASSY(RH,COMPATIBLE) 2 6272020290 WINDOW ASSY(LH) 4 6822020300 DOOR BELT WEATHERSTRIP ASSY(LH) 5 7555120520 ROOF DRIP SIDE FINISH(RH) *DISCONTINUED 6 7555220520 ROOF DRIP SIDE FINISH(LH) *DISCONTINUED This post has been edited by cellocinema: Sep 18, 2016 - 12:07 PM |
Sep 7, 2016 - 1:31 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
This is the outside weather strip that runs along the top of the door, it comes as a kit.
http://toyotamarket.ru/jp/252170/002/3/7503/1/75720/ 7572020400 LH 7571020400 RH See my thread about install I have a price of $219NZD retail, but last pair in country I got for $100NZD + GST http://i48.photobucket.com/albums/f217/shi...rs_complete.jpg 08613-20172 for the window drip guards These are a specialty part number, and from what I've seen looks to be an option on ST202 & ST205 celicas, it requires holes that you should have from factory Link to my thread with a picture of them hope this helps -------------------- |
Sep 7, 2016 - 10:22 AM |
Thanks a lot for your input.
Ok, finally here comes a complete list for restoring exterior side window moldings 1 6271020260 WINDOW ASSY(RH) 1' 6271020290 WINDOW ASSY(RH,COMPATIBLE) 2 6272020290 WINDOW ASSY(LH) 3 7571020400 OUTSIDE WEATHERSTRIP ASSY(RH) 4 7572020400 OUTSIDE WEATHERSTRIP ASSY(LH) 5' 7555120510 ROOF DRIP SIDE FINISH(RH, COMPATIBLE) 6' 7555220510 ROOF DRIP SIDE FINISH(LH, COMPATIBLE) *7 0861320172 optional window drip guards This post has been edited by cellocinema: Sep 18, 2016 - 12:01 PM |
Sep 13, 2016 - 1:43 PM |
ughhh i avoided replacing that part. im restoring as well. its $80 per side (with discount)
Sep 17, 2016 - 12:22 AM |
thanks for your input. i updated the list. roof drip side finish is almost $130 each(us dealer). it was a bit too much so i decided to sand them down a bit w/ 2000 grit sand paper and put window drip guards to conceal the aged surface. hope this plan goes well.
This post has been edited by cellocinema: Sep 17, 2016 - 8:35 AM |
Lo-Fi Version | Time is now: January 10th, 2025 - 9:21 PM |
