Water Temp Gauge Acting Up |
Aug 11, 2016 - 9:14 PM |
Enthusiast Joined Apr 7, '15 From New Mexico Currently Offline Reputation: 0 (0%) |
I have a 5sfte with a DIYPNP standalone ECU. My water temperature gauge started acting up recently. When I turn the key to the on position (car not started and cold) the needle goes all the way to hot. Then when I start the car it drops all the way to cold and stays there. When I get the water temp reading off my ECU it shows the temperature as normal when the car is fully warmed up so this looks to be some type of problem with the water temp sender, wire, or gauge. I have replaced the water temp sender with a brand new one and the problem is still the same. I have looked at the factory wiring diagrams and it looks like the water temp sender (different from the water temperature sensor) is wired directly to the gauge (no ECU connections) and is grounded at the intake manifold. I do not feel comfortable driving the car with no insight into how the car's temperature is performing and I do not want to have to have a laptop plugged into the ECU all the time to get that information. What would be the best way to test the wire and gauge to determine the problem? Has anyone experienced this problem?
Aug 20, 2016 - 3:38 PM |
No responses? I have toned out the wire and check continuity, everything was fine. The Haynes manual says there is a fuse for the gauge. I found one labelled "gauge" so I checked it and it was fine. The only other thing I can think of is that the gauge has gone bad. Any ideas?
Aug 20, 2016 - 7:17 PM |
Sorry just now saw this for some reason. There are two coolant temp sensors, one for the ECU and one for the gauge.
Scratch that just reread where you replaced it. If it's any consolation the gauge in the car is a dummy gauge and by the time it hits hot it's too late, I'd get a good aftermarket gauge to use then you can have absolute piece of mind. This post has been edited by Box: Aug 20, 2016 - 7:19 PM -------------------- 2001 Miata LS 5-speed
Aug 20, 2016 - 7:25 PM |
Sorry just now saw this for some reason. There are two coolant temp sensors, one for the ECU and one for the gauge. Scratch that just reread where you replaced it. If it's any consolation the gauge in the car is a dummy gauge and by the time it hits hot it's too late, I'd get a good aftermarket gauge to use then you can have absolute piece of mind. I was thinking the same thing. I have a spare gauge cluster, if I cannot get it to work when I swap the temp gauge into it, I think I will add an aftermarket one. |
Aug 21, 2016 - 3:24 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
You can always run an aftermarket water temp gauge. That's the best bet since you're turbod aND knowing how your engine is running is critical.
Aug 21, 2016 - 5:35 PM |
You can always run an aftermarket water temp gauge. That's the best bet since you're turbod aND knowing how your engine is running is critical. Just ordered one, I plan to install it next weekend. I went with a digital gauge so I will know exactly what is going on with my coolant temps. This post has been edited by HardHead93: Aug 25, 2016 - 10:30 AM |
Aug 24, 2016 - 7:02 PM |
the gauge temp sensor is the the single wire. pull the cluster out and shoot continuity from the cluster to the sensor pin. you should get less than 1 ohm. If that is good then shoot continuity from the sensor pin to the body of the sensor. with the engine running, that reading should change.
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:46 PM |
