> Wheels, Help Me, I need some help about wheels and wheel offset
post Aug 28, 2016 - 4:43 AM
DillonMulholland
Joined Aug 21, '16
From Queensland Australia
Im wondering if These Rota Grids will fit. They are 17/8+44 but have been told it might hit the suspension because of the offset. Can anyone confirm??
Also what Rims have yous been running? What is nice on a celica looking at 16/17 inches.
Cheers
post Aug 28, 2016 - 10:13 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
There's two threads on this already, with a table showing what wheels fit.
I don't think these will hit the suspension depending on tire size, but they'll be fairly sunk
My Celica!
post Aug 28, 2016 - 4:57 PM
trdproven
Joined Aug 2, '05
From Guam
dont mess with anything in the high 30s and up.
and if you plan to run flush I suggest dont look at the charts that are listed here. none of them were accurate because they don't account for ride height, camber, tire size, etc. Just measure your own set up and go from there. measure for outside movement and measure for inside clearance. and then use an offset calculator if you're not verse on measuring off the top of your head.
you'll need to select the right tire size as well when doing this, camber, and height, so there are a lot of variables. fender rolling may come into play if necessary.
This post has been edited by trdproven: Aug 28, 2016 - 5:01 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 29, 2016 - 12:53 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I raneed 17x8 +35 225.45.17 and my tire rubbbed on my Megan racing coil over.
post Aug 29, 2016 - 4:01 AM
trdproven
Joined Aug 2, '05
From Guam
I'm even running tucked on 18x9.5 +23 225/40/18
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 6, 2016 - 11:33 PM
Jvillie96
Joined Jun 21, '15
From North Carolina
QUOTE (ILoveMySilly97 @ Aug 29, 2016 - 12:53 AM) *
How bad was it rubbing? I'm lowered on Tanabe springs with stock struts. I recently ordered some 225/45/17 for my wheels with the same specs, 17x8 +35
post Oct 20, 2018 - 9:47 AM
CoolZeen
Joined May 30, '16
From wild 100's, South Chicago
QUOTE (Jvillie96 @ Oct 6, 2016 - 11:33 PM) *
Same question. Because I'm on that , to.
Lo-Fi Version Time is now: November 27th, 2024 - 4:21 PM
