> Axle bearing carier for a 1mzfe swap with a s54
post Sep 17, 2016 - 7:16 AM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
Need to know what axle bearing carrier I need to use. I tossed the auto one from my 1mzfe auto tranny by accident. My question is will the auto one work or do I need to modify the s54 hanger?
I am talking about the part that bolts to the 1mz motor where the passenger side axle half shaft sits.
post Sep 17, 2016 - 2:31 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if you are using the S54 you need to fabricate one yourself. If you are using an E153 you use an 05 Sienna
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 17, 2016 - 2:36 PM
doory100
Joined Jun 21, '14
Yes I'm using the s54. So I need to fabricate the hanger from the 5sfe motor onto the 1mzfe. Any tips? Thanks again smaay
post Sep 17, 2016 - 2:47 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah I made my own, i cut a hole the size of the axle bearing and mounted it to the axle, then lined everything up and welded it all together
post Sep 17, 2016 - 2:50 PM
doory100
Joined Jun 21, '14
I'm just going to fabricate some kind of adapter at work so I can pull s54 hanger right onto the engine where are the original hanger was.
BTW how did you weld it onto the engine because it is Aluminum block and the hangar is made out of steel unless you use an aluminum one.
This post has been edited by doory100: Sep 17, 2016 - 2:51 PM
post Sep 17, 2016 - 4:53 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
no i welded it to a plate that bolted to the block
post Sep 30, 2016 - 6:46 PM
doory100
Joined Jun 21, '14
What lower rad hose did you use on your swap?
post Oct 2, 2016 - 9:49 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
if you have a GT i made a hard pipe in an L shape then use rubber couplers. If you have an ST, use the stock hose and radiator
Lo-Fi Version Time is now: November 23rd, 2024 - 8:40 PM
