> FS: Legit ST205 1997 Celica already registered in the US, It's the real deal and I am finally parting with it
post Oct 12, 2016 - 1:15 AM
scottinalaska
Joined Feb 25, '16
From password
1997 Toyota Celica. If you have scrolled down to this description, then you know you may have stumbled upon a unicorn. Yes, this is the real deal. Skylines are cool, but more common, much more common! This is the 3rd and last generation Alltrac Celica. It was Toyota’s last rally car. It is built for abuse with a bullet proof drivetrain and suspension. You folks with the earlier Alltrac Celicas know to import this transmission and rear differential. This is already factory installed! Examples of it in New Zealand and Australia are often very molested and beat, but still running Sadly, this model trophy car was never imported to North America. Until now.
There was one loophole and this one slipped through it. Here in Alaska, apparently our Japanese diplomat brought over his personal car, this GT4, in the late 90’s. In order to have it “official,” he apparently had all the things done to make it legal (glad I didn’t pay for all that!). So it has dual airbags, ABS, daytime running lights, and whatever was needed to get the stickers issued approving it for US Federal safety, theft, and emission standards in the US. He even had the speedometer changed to display miles. It still has his Japanese aftermarket cool radio in it that only goes up to FM 98. This means if you listen to FM 105, you’re out of luck! Thus, I have a clear, clean Alaska title ready to be registered in any other state (likely not California, of course!).
It is completely stock and has a practically perfect interior and exterior. Winter tires are like new on 16” rims. I also have 17" Speedline rims if you want those mounted instead. Having the taller sidewall helps in the snow and I didn't get around to changing them to the 17" rims this summer. A/C is ice cold. The TRD side skirts are factory installed. The 12 digit VIN has been expanded to 17 numbers for Ebay along with changing it to a 1980 model so they would accept the listing.
A few features which are pretty stock for this model Celica:
Power windows
Rear wiper
Power mirrors that power fold in too.
Rear strut brace (factory).
Sunroof delete – stiffer body.
2.0 Turbo twin entry, 5 speed (smooth and perfect).
New front struts.
New brakes all around.
Windshield is practically perfect with NO cracks or bullseyes.
Here is the list of the “bad”:
Slight rock ding in front on hood– I’d have to point it out because it is so small, but no missing paint.
The bezel cover for the sunglass holder in the headliner is missing. I might find it before you get it, but no promises!
There was a previous silver paint touch up done with a small brush on the leading side of the driver's door. I haven't done any touching up myself, so it's not my fault someone did a poor job! One of the pics show that "repair." It's not bad, and I don't really notice it unless I bend down and look right there!
At 63K miles, it is due for a timing belt according to Toyota.
The clutch will slip if you spool the turbo hard in 4th or 5th gear. It’s not noticeable in the lower gears unless you romp on it, but the clutch should be scheduled as well. I drive it around, even in the winter. It is the best fun drifter car I have driven – smooth, balanced, and predicable. No, I don’t toast my tires - this is in snow covered school parking lots at nights in winter! Understand, I drive this car. I don’t fear driving it ANYwhere all year and never abused. But it is also likely one of the best condition Celicas you’ll find and the only GT4 you’ll find for sale in the US.
Included is a couple links to two videos of me walking around the car and looking under the carpet in the trunk. I know it is a long ways away to see a car, so I am trying to show you what I can so you’ll know very completely what you’re getting if you decide to bid. I think it is important to see as much “bad” as you can. The car doesn’t show any signs of any accidents. I took pics of the interior of the trunk with the rear panel removed so you can see nothing is hidden.
That’s it. Really! Even if it was a boring stock front wheel drive Celica, it is likely one of the finest examples around. No tears, hardly any noticeable wear or wrinkles in the upholstery. No rust. No leaks. Fresh Toyota fluids. I run 3K miles on synthetic oil and change it. It comes out golden every time. It uses no oil which is not surprising for a low mileage Toyota. Everything is there from the jack to the spare to the original Japanese flare secured under the dash. This was always a non-smoker car and has no smell at all.
These links below are for a video walk around.
https://youtu.be/pAnhMvVkVNE
https://youtu.be/lTnh3nsYJ4I
I even have the original sales brochure from Japan in 1997!
I can certainly provide more pictures if you need some. Texting can work. 9078857700.
Transportation can be 1500 - 2000 bucks anywhere in the US, Or you can drive it home from Anchorage, Alaska! I would not hesitate to drive it across Canada. I get better than 30 mpg if I keep it at 60. But that is what it was rated for in 1997. And yes, I have driven into Canada and back twice with this car. There are no issues with my plates or registration. Afterall, it's a Celica! Everyone likes and is familiar with a Celica!
Please don't let the fact that this car is in Alaska make you feel it is impossible to transport. It happens every day and I will work VERY diligently to make sure it makes it south smoothly.
In case you didn’t notice, it is a right hand drive car. This is completely legal in all states if that is a concern. Remember, mailmen are on the right side everyday! Oh, and the status factor of driving on the right is surprisingly cool. FYI, pedals are the same – clutch, brake, gas – just like the normal left side. Shift with your left hand instead.
I am asking 15K. In fact, if I get that, I'll make sure it is delivered to Seattle at no charge!
Well, enough of that. Call or text me if you're interested. I have a local guy wanting to buy it for 13.5 and will make a decision in the next week.
Scott
907-885-7700
Pics are below in the links. Sorry I couldn't make them embed. You'll have to work a bit to get to the silver car!
http://s1078.photobucket.com/user/scottinalaska/library/
<iframe width="480" height="360" src="http://s1078.photobucket.com/user/scottinalaska/embed/slideshow/"></iframe>
post Oct 13, 2016 - 5:41 PM
trdproven
Joined Aug 2, '05
From Guam
so nice
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 13, 2016 - 6:50 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Damn....so jdm!
post Oct 15, 2016 - 9:28 PM
CelicaDICE
Joined Nov 13, '14
From MIA
Rare JDM Dealer Option Parking(Proximitiy) Senor for sale
http://www.6gc.net/forums/index.php?showtopic=97051
post Oct 19, 2016 - 10:56 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
Clean car, glws!
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Oct 22, 2016 - 10:24 AM
Csober
Joined Jun 16, '16
From Lansing, Mi
This still forsale?
Technician @ Airlift Performance
*1993 Mitsubishi Eclipse GST*1992 Eagle Talon TSI
*1991 Toyota Celica GT*1998 Mitsubishi Eclipse GST
*1993 Toyota Celica GTS*1991 Nissan 300zx TT
*2006 Mitsubishi Evolution 9 563/403*1994 Toyota Celica GT ST205 rep.
*1995 Toyota Corolla (Beater
-2008 Honda Fit Sport (daily)
-1991 Nissan 300zx tt 632/520
Lo-Fi Version Time is now: February 21st, 2025 - 8:24 AM
