> Failed Smog Test - All Emissions High
post Nov 9, 2016 - 10:32 AM
blickman
Joined Feb 1, '14
From Phoenix
Hi. Could use some advice. 94 ST Manual rebuilt engine
Previously had CEL with code 071. Replaced ERG valve, EGR modulator, and 1 vacuum hose. CEL fixed.
Went to have car smogged and all emissions are high. Here are the numbers:
15 mph HC=95 CO=0.53 NO=795
25 mph HC=82 CO=0.41 NO=763
Not sure where to begin. Should I just replace both O2 sensors to start and then retest? Any advice appreciated.
Thanks!
Jay
post Nov 11, 2016 - 6:44 PM
blickman
Joined Feb 1, '14
From Phoenix
No one has any ideas at all??
post Nov 11, 2016 - 7:47 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Without knowing the limits and by how much you failed it's hard to say but just check that everything is in spec like ignition timing, plug gap, coil resistance, etc.
post Nov 12, 2016 - 9:47 AM
Probably running rich.
How old is the 02 sensor ?
post Nov 12, 2016 - 7:22 PM
blickman
Joined Feb 1, '14
From Phoenix
I don't know that it's ever been replaced.
post Nov 14, 2016 - 4:43 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
your NO is really high, try using 91 gas next time. also look for vacuum leaks and exhaust leaks
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 24th, 2024 - 3:34 AM
