> have fuel, have spark, cranks well, won't start
post Nov 10, 2016 - 9:52 PM
jnylaw
Joined Nov 10, '16
From Vancouver, WA
Hey all, I've got a 1995 Celica with a 2 L, that I gave a full tune up about 2 months ago. I was driving it with no problem, parked it at home and the next morning it would crank but no fire.
Since, I have checked resistance from coil and distributor. Both checked out fine. I have replaced fuel filter (just in case), seen that I am getting plenty of fuel. Bought a new fuel pump, thinking may be the problem. Did the starting fluid into throttle body, no fire.
My next suspicions are the timing belt jumping a tooth (don't see how this could be, as it was running fine when I parked it the day before) or the next is a plugged exhaust.
I'm out of options, if anyone has any ideas, I would greatly appreciate it.
Thanks in advance,
jnylaw
post Nov 11, 2016 - 8:25 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Is the spark strong and able to jump more than 1/4 inch gap in free air easily? A weak coil can check good but lack power to fire under compression.
post Mar 25, 2018 - 7:12 AM
longgone
Joined Feb 5, '10
From ireland
QUOTE (jnylaw @ Nov 10, 2016 - 10:52 PM) *
Thanks in advance,
jnylaw
I had the same problems a few years ago turns out it was pipe coming out of fuel tank was loosing pressure due to corrosion changed it and it started fine
post Mar 25, 2018 - 3:30 PM
ST204GT83
Joined Mar 6, '17
From Sacramento
I had this problem too, mine problem was fuel injectors.
QUOTE (ST204GT83 @ Mar 25, 2018 - 3:29 PM) *
*My problem
post Mar 27, 2018 - 2:47 PM
ST204GT83
Joined Mar 6, '17
From Sacramento
Check your fuel filter, and compression in cylinders too.
Lo-Fi Version Time is now: November 23rd, 2024 - 1:34 PM
