> Fuel Door Cable Tension ??
post Dec 13, 2016 - 11:49 AM
Mr_Man
Joined Dec 13, '16
From Bristol, UK
Hey people.
Got a '96 Celica 2.0 GT 3S-GE.
Yesterday the fuel door release lever came loose because over the years of pulling it, the cable has lost some of its tension.
I was just wondering if there's any way to adjust / increase the amount of tension on the cable? Does it have a tension adjuster on it??
By the way, for anyone in the same situation as me. If your fuel door won't open, this is what I did...
1. Remove the front seat by undoing the four 14mm bolts that attach it to the floor.
2. Yank up the plastic door trim that holds the carpet down (nothing to undo, just jank it upwards and it opos out ---- it'll pop back in too.
3. Pull the carpet away from the floor.
4. You have to pull the carpet back enough so that the trunk / fuel levers are completely revealed - fiddly, but pull the carpet away from those too.
5. You'll notice that the whole lever unit is housed under part of the metal - it is held in place by one 10mm bolt right next to it. Undo that.
6. Pull the whole unit backwards to remove it from underneath the metal frame, so it's free.
7. There should be two springs on each side of the levers (one of mine fell off, so I had to put it back on).
8. If these two levers feel loose, then you need to push them together until you hear a 'snap' as it all snaps together - there is no screw or bolt to hold these together, it's just a snap-in kinda mechanism.
9. At this point, if the fuel door doesn't open, get a friend to pull the fuel lever upward while you pry the fuel door open - then remove the locking bracket on the fuel door until you can fix the problem.
- Mr_Man   Fuel Door Cable Tension ??   Dec 13, 2016 - 11:49 AM
- - Rowatari   You can get at the end of the cable by opening the...   Mar 3, 2017 - 12:03 AM
Lo-Fi Version Time is now: September 17th, 2026 - 10:13 PM
