> 3S-GE Beams 187hp VVTI Pulley problem!! Please help, urgent.
post Mar 27, 2017 - 7:16 AM
shawns11
Joined Mar 27, '17
Hi everyone i have the 3sge beams engine with the black cover not redtop . 187hp version that came in rav4 etc
The problem is that the vvti system is making a constant noise and gets louder with the rpms. Car feels really down on power , most likely because the engines timing gets retarded.
The valve cover is now open and both cams are removed. I have sourced another VVTI pulley but this one is from a BLACKTOP Altezza RWD engine !! Can it be used on my FWD Beams?
post Mar 27, 2017 - 1:01 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
im not following... Pulley? whats a pulley????
post Mar 27, 2017 - 6:33 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you mean the cam gear? if they are both from a blacktop it should be fine
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 27, 2017 - 9:05 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
The part number is 13050-74020 and cross references between the MR2, RAV4, Celica and Altezza, so yes, it is interchangeable. Did you check the oil control valve and filter before assuming the pulley has gone bad? What weight oil are you using? Are you positive that the noise wasn't coming from the timing belt, maybe the tensioner got loose and timing skipped a tooth?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: November 29th, 2024 - 7:47 PM
