Alwayzsidewayz Project Sky, ST202 UK car total rebuild |
Mar 31, 2017 - 2:39 PM |
Enthusiast Joined Aug 5, '13 From England UK Currently Offline Reputation: 0 (0%) |
Hi All,
Been active on the FB pages so thought I should share here. I am building my dream ST202. I have had a number of Celica’s in my car history, but this one called “Sky” is my forever car. It’s my 100th car I have owned. I have become obsessed with getting this on spot on. Currently she is in a complete very smart state, awaiting a full tear down from top to bottom and a total new build. Planned Spec is as follows. Engine Based upon a rev 3 3sge block and head Block – Chemically cleaned, line honed and corrected, 86.5mm bore Gen 3 Genuine Toyota 86.5mm pistons and completion spec Rings Forged H Beam lightweight connecting rods Tri-metal completion bearings Dynamically balanced, ground and polished crankshaft ARP cylinder head studs Competition MLS head gasket Uprated Piper valve springs Ported Cylinder head Shimless “solid” lightweight lifters Long Duration high lift camshafts (ground from blanks) Piper Venier Pulleys Hurley Phenolic inlet gasket Hurley 45mm throttle body kit, using Jenvy Throttle bodies Custom intake Ramair Air filter Hurley 24-2 wasted spark trigger kit – (magnetti Sensor) Celica T230 Coil packs New Injectors Adjustable fuel regulator Upgraded fuel pump, twin set up with swirl pot Alloy Rad Custom expansion tank Billet oil cap Custom painted rocker cover Ally Catch tank Aeroquip hosing throughout Misimoto PAS cooler New starter motor and alternator Custom water pump Remote electrical thermostat Exhaust is as follows Japspeed Ceramic coated Exhaust manifold Decat HKS Super dragger exhaust system This will be run on a custom loom by a link G4+ Fury ECU Transmission S54 box fully rebuilt Kaaz LSD ARP flywheel bolts Hurley lightweight 3sge flywheel Black diamond stage 2 clutch Toyota new release bearing BRD poly gearshift bushes TRD short shifter kit New Toyota master cylinder Rebuilt Drive shafts Suspension All new refurbished hubs front and rear Powder coated rear beam, cross members and wishbones Super strut front cross members Super strut steering rack BRD poly steering bushes Whiteline and GT4 – play poly bush kit throughout front and rear Cusco front under brace Front strut brace BC BR coilovers Hardrace rear arms Ultra rear sway bar Whiteline drop links Powder coated front sway bar GT4 rear strut brace All new inner and outer tie rods, ball joints etc All new Toyota bolts, nuts, washers and fixings Custom spacers front and rear Brakes KSport 8 pot front calipers in red with 330mm discs and blue stuff pads Ksport 4 pot rear calipers in red with TBC discs and blue stuff pads Custom brake stopper ABS stripped out AP racing brake proportioning valve All new lines Wheels and tyres Rays Volk GTP Daytona 17 x 8 lightweight rims 215 40 falken rubber Body Battery relocated to the boot BRD poly engine mounts Custom vented bulkhead for intake Seam welded engine bay Smoothed and tucked engine bay TBC body kit Carbon rear plate surround, number plates and window deflectors Carbon capped mirrors Smoothed rear tailgate, no badge, or rear wiper or high level brake light Import rear lights with LED conversion Rear diffuser Rolled front and rear arches All New rubbers New windscreen Carbon hood with custom vents Projector front lights Crystal indicators Colour change Fully painted inside and out Interior Dash 2 pro electronic dash Tablet with Android Link software for centre dash display Custom leather front and rear seats and door panels Mono Monte Carlo steering wheel New carpets Hyper sport mats LED interior lighting Leather trimmed interior inc dash Alloy pedals and accents etc Plus More Current state of play is as follows I have the engine all built. It’s sat waiting in the garage 17498470_10212145758510341_2285727355440895122_n by Richard Morrow, on Flickr 17458125_10212145758870350_7968047748287389662_n by Richard Morrow, on Flickr I have pretty much all the parts bar the body kit, rear brakes, and ecu plus dash Current state of the interior IMAG3205 by Richard Morrow, on Flickr IMAG3204 by Richard Morrow, on Flickr Wheels IMAG2639 by Richard Morrow, on Flickr Current engine bay 15541983_10211189839132954_7436297401766375026_n by Richard Morrow, on Flickr The car is going to go soon up to the shop which is helping me with this, so it can be tore down to a bare shell. Then it will be stripped back to bare metal, any rust damage etc fixed and the metal work mods can start. I plan to have the car built over the course of this year and then ready for the 2018 show and track day year. The car is being built to the best I can do, so it’s all new bolts and the best I can afford in terms of set up. A set of track rims is under consideration, with track rubber, as the car will see track action, along with show and shine work etc The car is slightly famous already, I purchased it last summer, from a good friend, who had already started the mods and got the car featured in a car magazine. IMAG1945 by Richard Morrow, on Flickr How I first got car IMAG1944 by Richard Morrow, on Flickr IMAG1943 by Richard Morrow, on Flickr IMAG1942 by Richard Morrow, on Flickr Since I have owned the car, I have added a lot of mods, that I already had, such as Koni adjustable suspension for the front and KYB for the rear with Eibach springs, the rims, the interior, the lights, the HKS and K& N filters, chrome detailing etc. How she sits right now 16427464_10211671652297982_5365202565806282193_n by Richard Morrow, on Flickr IMAG2681 by Richard Morrow, on Flickr IMAG3194 by Richard Morrow, on Flickr The car is super straight and very very clean; I wanted the best base for the build possible. Anyway below are a few pics to give you the idea. https://www.flickr.com/photos/149025875@N03/shares/x8bcRQ https://www.flickr.com/photos/149025875@N03/shares/z07PT6 https://www.flickr.com/photos/149025875@N03/shares/uR2989 https://www.flickr.com/photos/149025875@N03/shares/z11tK8 This post has been edited by alwayzsidewayz: Apr 1, 2017 - 4:08 AM |
Mar 31, 2017 - 8:16 PM |
I should explain that all the current mods and parts fitted to the car, like the genuine ss3 spliters front and rear, adj shocks etc, will be kept, as while the car is being built, I plan on getting another 6 and modding that for the wife. Although she has a project Mazda. I have lots more pics if people are interested. From small stuff like the TRD fuel cap, to the full engine build. Happy to post if anyone wants some more pics or info?
Few more parts pics carbon mirror caps with puddle lights IMAG2637 by Richard Morrow, on Flickr IMAG2634 by Richard Morrow, on Flickr lowered on Eibach springs IMAG2617 by Richard Morrow, on Flickr rear seats with head rests IMAG2388 by Richard Morrow, on Flickr GT4 rear brace IMAG2386 by Richard Morrow, on Flickr Rims IMAG2342 by Richard Morrow, on Flickr crystal vs stock indicators IMAG2076 by Richard Morrow, on Flickr TRD filler cap IMAG2011 by Richard Morrow, on Flickr New filler neck to go on brand new toyota IMAG2000 by Richard Morrow, on Flickr Volvo washer jets IMAG1956 by Richard Morrow, on Flickr couple more engine pics 17424644_10212145757070305_8760239918016161734_n by Richard Morrow, on Flickr 17309760_1270808206329716_6297251304725578772_n by Richard Morrow, on Flickr 17264107_10212069433362260_6280999380765016962_n by Richard Morrow, on Flickr rear carbon plate and surround 16473617_10211671651337958_2218694586403456461_n by Richard Morrow, on Flickr Manifold and downpipe, not yet coated 14457351_10210339169506745_8720079842920876168_n by Richard Morrow, on Flickr Wishbones 14333097_10210207395612480_2835658052139904759_n by Richard Morrow, on Flickr Rear beam 14322337_10210207398052541_1409568777546314800_n by Richard Morrow, on Flickr Exhaust HKS 14199595_10210101834333514_8372068187105666687_n by Richard Morrow, on Flickr 14102736_10210101831813451_2417304133155332523_n by Richard Morrow, on Flickr 14117921_10210101832933479_4660250028945179379_n by Richard Morrow, on Flickr rear clear brake light 13962622_10209933741531299_502090890368163828_n by Richard Morrow, on Flickr Suspension fixings 13925089_10209926752236571_3464047106471436601_n by Richard Morrow, on Flickr Billet Works oil cap 13726576_10209701659929404_5032679140603382231_n by Richard Morrow, on Flickr LSD 216 by Richard Morrow, on Flickr Clutch 215 by Richard Morrow, on Flickr 214 by Richard Morrow, on Flickr Coilovers 205 by Richard Morrow, on Flickr Rear sway bar 204 by Richard Morrow, on Flickr Hardrace rear arms and Cusco brace 203 by Richard Morrow, on Flickr Carbon wind deflectors 15192765_10210941187316814_4810722722868910529_n by Richard Morrow, on Flickr Lots more too, but thought I would share a few more. This post has been edited by alwayzsidewayz: Apr 1, 2017 - 4:29 AM |
Apr 1, 2017 - 2:48 PM |
Wow haven't seen a build like this in a while. Brakes seem overkill? Maybe save the money and go ST205 brakes? But my guess is that you want that set up because you can get a 2 piece rotor configuration...
Apr 1, 2017 - 3:18 PM |
Hi, cheers for the feedback. Brakes are a bit OTT, but as you say, I want the rotor set up. The bias valve will help as we dial them in, as I am dumping the abs too.
Apr 1, 2017 - 3:58 PM |
Enthusiast Joined Aug 22, '06 From Belgium Currently Offline Reputation: 0 (0%) |
Very nice setup.
What is your impression on the Ksport brakes? |
Apr 1, 2017 - 4:06 PM |
No idea, not on the car yet, won't be until the shell is stripped and build up starts. Having had custom bells with 330mm discs with 205 calipers before on my 165, I hope they are a match for those if not a step up. Huge amount of work still to do on the build.
Cheers for the feedback. |
Apr 1, 2017 - 7:15 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
welcome!
wow! very interesting build. looking forward to seeing more of this. -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Apr 4, 2017 - 12:05 PM |
Gorgeous! Great taste.
'93 MX-5 LE |
May 9, 2017 - 3:15 PM |
Few recent shots inside and out.
New handbrake parts after pattern stuff failed and some new carbon Fibre goodies! 17883556_10212294650232541_4096861997155109158_n by Richard Morrow, on Flickr 17800485_10212294653552624_5111001236905149639_n by Richard Morrow, on Flickr 17799269_10212294652432596_1332792630657591718_n by Richard Morrow, on Flickr 17796859_10212294651472572_792270052022392678_n by Richard Morrow, on Flickr 17634697_10212294653272617_918556076614511088_n by Richard Morrow, on Flickr 18157693_10212496703323742_2022314849094652888_n by Richard Morrow, on Flickr 18301669_10212601409781338_8891410220798927482_n by Richard Morrow, on Flickr 18301710_10212601409381328_1671452117951056220_n by Richard Morrow, on Flickr 18342409_10212601408821314_4066372812911924401_n by Richard Morrow, on Flickr Very happy with the carbon parts, lot more to come. Just ordered coil packs for the motor, and sadly having to do a quick overhaul of the Master cylinder as brakes are a touch soft despite bleeding. but hey ho, its a celica, always parts to fix |
Aug 17, 2017 - 6:19 AM |
anything yet???
Aug 24, 2017 - 4:43 AM |
Enthusiast Joined Mar 24, '15 From SC Currently Offline Reputation: 0 (0%) |
Nice work! Those CF parts will surely make your car more sporty looking.
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:36 AM |
