> Outrageous emissions readings?
post Apr 14, 2017 - 6:42 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
My registration is due to be renewed by the end of the month, so I went to my usual emissions station. My engine and cat were already plenty warm by the time I arrived, but the guy was out on an errand, so I sat idling for about 10-15 more minutes. These were my high RPM readouts:
This is crazy - they have never been so high. This time last year, HC was only at ~40 and CO was something around 0.6-0.65. What could've gone bad between these two readings to make it jump so drastically?? My Celi drives the same, idles the same and gets the same MPG as last year. No CEL either.
Earlier today I removed my battery for access to replace my motor mounts. The only thing that crosses my mind is that maybe the A/F ratio got reset. The battery was out for ~1.5 hours or so. I drove for roughly 10-15 minutes to get to the emissions station after that.
Any ideas, guys?
June '12 COTM
'95 AT200
post Apr 14, 2017 - 6:59 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
give it a good italian tune up then try again.
post Apr 14, 2017 - 7:45 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Bitter @ Apr 14, 2017 - 5:59 PM) *
Poured wine into the oil input and now the car won't start.
Halp.
June '12 COTM
'95 AT200
post Apr 14, 2017 - 8:26 PM
Bitter
Joined Mar 11, '06
you're supposed to put salami up the tail pipe.
https://en.wikipedia.org/wiki/Italian_tuneup
post Apr 14, 2017 - 8:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
Italian tune up=drive the hell out of it to blow the carbon out. It sitting an idling right before testing is what failed you. Drive it hard to the testing station and if they can't immediately test it turn the car off, don't let it sit and idle.
2001 Miata LS 5-speed
post Apr 14, 2017 - 8:44 PM
Bitter
Joined Mar 11, '06
If they can't test it right away do a ****ing burnout in the parking lot, hot lap the block, then pull back in sliding sideways with the brakes locked up and ask if they've got time to do it now.
post Apr 15, 2017 - 5:29 AM
Box
Joined Feb 23, '12
From Warrior, AL
laugh.gif I think that might cause a whole new set of problems.
post Apr 15, 2017 - 7:02 AM
Oreo20
Joined Jan 27, '14
From Houston
Happened to me
I had very high emissions with no check engine everything runs fine bla bla turned out to be the cat but the one in the front
Apparently it had no honey combs lol was running rich the whole year and made me fail new cat 400$ on the GT
post Apr 15, 2017 - 3:12 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Oreo20 @ Apr 15, 2017 - 6:02 AM) *
Happened to me
I replaced my cat on January of last year... I don't think it would be the cat. Hopefully not, anyway. And it's a 7A, so I've only got one cat.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: November 23rd, 2024 - 7:22 AM
