> Tranny fluid
post Feb 22, 2004 - 11:39 AM
7A-FEces
Joined Feb 21, '04
From Oklahoma
What does the Celica use for tranny fluid? Tegs use regular 5w-30 oil. Was wanting to change it out. Also how much does it need. I have an 5 speed ST.
This post has been edited by 7A-FEces: Feb 22, 2004 - 11:56 AM
post Feb 22, 2004 - 12:43 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (7A-FEces @ Feb 22, 2004 - 9:39 AM)
Ive heard good things about penzoil synchromesh, suposedly it really smooths out shifting. I think you might need a little over 4 quarts? And Im not sure on the rating.
This post has been edited by Uppitycracker: Feb 22, 2004 - 12:43 PM
post Feb 22, 2004 - 1:27 PM
97GTinKC
From KC
From Amsoil's website:
Picked 96 ST as I didnt know what year you have for sure, If different, go here:
Amsoil lookup
1996 TOYOTA CELICA 1.8L 4-cyl VIN Code E 7A-FE
FILTERS
Oil Filter......SDF10
Air Filter......TS09
Fuel Filter......GF288
PCV Valve......HV105
Trans......TF117
BOSCH SPARK PLUGS
ST
Wire......B09822
Plug......B4417
BOSCH WIPER BLADES
Driver side......B40921
Passenger side......B40920
Rear window......B40920
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil (TSO)
SAE 5W-30 SYNTHETIC MOTOR OIL (ASL)
Synthetic XL-7500 Motor Oil (XLF, XLM, XLT)
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD)
Grade 2......API*
Above 0°F......10W-30
Below 50°F......5W-30
Manual Transmission,.....GL-4
All temps......75W-90
Series 2000 Synthetic Gear Lube (TGR)
Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO)
Manual Transmission,.....GL-5
Automatic Transmission,3-spd.....AF3
Synthetic Automatic Transmission Fluid (ATF)
Differential, Front .....AF3[1]
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
1. Final drive for automatic transmission only.
CAPACITIES
Engine, with filter..........3.9 quarts[1]
Cooling System, W/ AT Initial Fill..........6.9 quarts
Cooling System, W/ MT Initial Fill..........6.4 quarts
Automatic Transmission, Initial Fill..........3.5 quarts[2][3]
Automatic Transmission, Total Fill
A246E..........8.1 quarts
A140E..........5.9 quarts
Manual Transmission, From 5/95..........4.0 pints
1. Capacity shown includes filter. After refill check oil level
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
3. Findr will refill w/ trans through dipstick tube.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission
Fill Plug.....36 ft-lbs
Drain Plug.....36 ft-lbs
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
My Amsoil site
post Feb 22, 2004 - 1:50 PM
ghostdog
From ny to philly
post Feb 22, 2004 - 2:29 PM
abatardi
Joined May 8, '03
From San Jose, CA
mobil 1 + lucas gear oil.
- aba
post Feb 22, 2004 - 3:42 PM
snadman
From Minnesota, USA
QUOTE (abatardi @ Feb 22, 2004 - 12:29 PM)
- aba
Good call, the Mobil and the Lucas are both great products. When people come into the Napa store I work at, I always point them in the direction of Mobil and Lucas products.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Feb 23, 2004 - 10:50 AM
7A-FEces
Joined Feb 21, '04
From Oklahoma
Thanx guys. So regular mobil 1 will work then? And 97 gtinkc is the 75w-90 the oil grade I need if I were to get amsoil? And what is 5.3 pints in qts?
post Feb 23, 2004 - 2:12 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
in my c52 (in a corolla, should be nearly identical for your celica st) tranny we put in 85w-90 gear oil..... it's a bitch to get in.... and we needed 2.7 quarts
when you fill it (the fill bolt is on the side of the tranny near that top, should be facing you when you open the hood) you should be able to just stick the tip of your pinky into the oil when you put it into the fill hole....
post Feb 23, 2004 - 2:33 PM
aaronc222
Joined Sep 22, '02
From Detroit
The factory recomended(sp?) oil is 75w90. And as far as pouring the oil, it's much easier with a 'beer bong' type funnel.
post Feb 23, 2004 - 3:02 PM
7A-FEces
Joined Feb 21, '04
From Oklahoma
Guess I'll buy 3 qts then. Planning to do a swap so I'll just use the regular 75w-90 on my ST's tranny.
post Feb 23, 2004 - 5:04 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (aaronc222 @ Feb 23, 2004 - 7:33 PM)
we used the pointed bottle and hooked a long hose up to it so that we could squeeze the bottle and the oil into it.... still took about 20 minutes though
post Feb 26, 2004 - 3:34 AM
saleeka
Joined Sep 4, '03
From Twin Cities MN
how much should i pay a shop to swap the tranny oil in my stick? I have no idea how to do this stuff rolleyes.gif so i'd like your guy's knowlegable opinions on this please biggrin.gif
post Feb 26, 2004 - 11:50 AM
abatardi
Joined May 8, '03
From San Jose, CA
QUOTE (saleeka @ Feb 26, 2004 - 1:34 AM)
I wouldn't pay them more than it costs to get an oil change. It's about the same, except it takes longer to put the tranny fluid in and there's no filter to change.
It's easy... there are two pretty big bolts on the tranny. One about halfway up the side (the fill plug) and one on the bottom (the drain plug). open drain plug, drain fluid, replace drain plug, open fill plug, put in fluid (it should take like 2.6 quarts - stick your pinky in the fill plug when you are getting close to see if you can feel the fluid level up to the fill plug yet).. replace fill plug and you're done.
the hardest part is getting the filler plugs off. It's either a 24 or 26mm bolt I think.
- aba
This post has been edited by abatardi: Feb 26, 2004 - 11:51 AM
Lo-Fi Version Time is now: February 23rd, 2025 - 12:39 AM
