5SFE swap electrical issues. Please help. |
May 24, 2017 - 12:32 PM |
Enthusiast Joined Mar 24, '17 From Las Vegas Currently Offline Reputation: 0 (0%) |
Everything is good now thank you!
This post has been edited by brandon702bmx: May 25, 2017 - 12:35 PM |
May 24, 2017 - 6:52 PM |
If you're getting a single tap then the starter solenoid is at least getting power, pull the starter and bench test it before you run out and get one, if it bench tests fine then either it's too weak to spin the engine or the power feed or ground feed is too weak to give it the power to spin the engine.
May 24, 2017 - 9:34 PM |
Turned out to be the stupid fuse box giant plug. The little brace that holds it in place has to be clipped and up for the electrical connections to work. Car started... now unfortunately... my fans will not kick on and it overheats.
May 24, 2017 - 10:31 PM |
use a test light, the big wire that is bolted to the starter is constant battery power. the black plug is key switched power. pull out the plug and stick the test light into it. turn the key to start and see if the test light comes on. if it does then you are getting proper power to the starter. if it does not, then you have an electrical issue. check relays and fuses
This post has been edited by Smaay: May 24, 2017 - 10:31 PM -------------------- 2001 Celica GT-S Turbo
May 25, 2017 - 12:34 PM |
use a test light, the big wire that is bolted to the starter is constant battery power. the black plug is key switched power. pull out the plug and stick the test light into it. turn the key to start and see if the test light comes on. if it does then you are getting proper power to the starter. if it does not, then you have an electrical issue. check relays and fuses Thank you! I did. It happened to be something very stupid and minor but frustrating. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:04 AM |
