Power steering leak |
May 25, 2017 - 3:51 PM |
Enthusiast Joined Mar 24, '17 From Las Vegas Currently Offline Reputation: 0 (0%) |
I have a question. I recently did an engine swap on my 1994 Celica GT. The power steering is leeking from the hose that connects to the pump itself.
The ending with the "O" is and the bolt goes through. I currently have a copper washer on both sides of that built but it leaks terribly... so on one side I stuck 2 copper washers on and it doesn't leak as bad... still drips. My question is... is there supposed to be an O ring on one side if so where and to what specification. I need help getting it to stop leaking and I know it's the source but I can't remember how it was assembled before I took it off to swap engines. Thanks guys. |
May 25, 2017 - 6:04 PM |
You'll just need new copper crush washers. They are available at almost every parts store.
May 26, 2017 - 11:58 PM |
Enthusiast Joined May 11, '09 From California Currently Offline Reputation: 4 (100%) |
As stated, copper crush gaskets and I goes:
Banjo Gasket Line Gasket Pump Also make sure you torque the hell out of it. -------------------- |
May 27, 2017 - 6:02 PM |
As stated, copper crush gaskets and I goes: Banjo Gasket Line Gasket Pump Also make sure you torque the hell out of it. Perhaps the fact I was trying to get away with the old washers is the reason why I still have a leak... Thanks guys I really do appreciate it as this swap is hopefully gonna be done soon... |
May 28, 2017 - 4:05 PM |
had the same issue and replaced that weird double looking washer and no more leak. hopefully it works for you
May 28, 2017 - 9:22 PM |
If you're really in a bind you can re-soften the copper washers by heating them up real hot over a stove or torch flame and then letting them air cool, then sand them flat, they'll reseal well enough to get you home or to the parts store.
https://www.youtube.com/watch?v=RMLqlDSsQpA This post has been edited by Bitter: May 28, 2017 - 9:24 PM -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 3:24 AM |
