FS: 96+ diamond clear indicators, SOLD. Mods, please close. |
May 30, 2017 - 11:53 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
$35 shipped anywhere in the continental US.
TRD rad cap was sold. This post has been edited by HectortheRican: Aug 21, 2017 - 9:10 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jun 5, 2017 - 8:51 PM |
bump
added to original post -------------------- taking too long to mod since '09
Jul 1, 2017 - 2:43 PM |
bump
Jul 4, 2017 - 8:35 AM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Im curious, what's the purpose of a high pressure rad cap?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jul 5, 2017 - 3:09 PM |
Im curious, what's the purpose of a high pressure rad cap? It allows the engine to run a bit hotter, since it will take a higher coolant system pressure to cause a boilover into the reservoir under high loads. Probably not too ideal for daily driving, but a good upgrade for any sort of racing - especially if you're running a higher-capacity aluminum radiator. -------------------- taking too long to mod since '09
Jul 20, 2017 - 8:29 PM |
http://www.tuneruniversity.com/blog/2011/0...e-radiator-cap/
Hmm ill be buying the turn signals from you soon enough to answer you question. you can run a 70 solution distilled water to 30 coolant ratio when on the track since water dissipates heat from engine better than coolant. a 50/50 ratio of coolant to water isn't ideal on the track. but water also freezes at 32 degrees, but running water all the time even in warm climates causes rust in engine. This post has been edited by BonzaiCelica: Jul 22, 2017 - 9:11 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Jul 30, 2017 - 4:32 PM |
Enthusiast Joined Dec 16, '07 From Chicago, IL Currently Offline Reputation: 10 (100%) |
Payment sent for the trd radiator cap
-------------------- 1999 Celica GT Hatchback
Aug 21, 2017 - 9:01 PM |
mods might want to close this now!!
Lo-Fi Version | Time is now: November 22nd, 2024 - 12:58 AM |
