Enthusiast ![]() ![]() Joined Apr 24, '14 From Durham, NC, USA Currently Offline Reputation: 0 (0%) ![]() |
1994 Celica ST 1.8L AT200 with manual transmission:
I think I have heard it called a 'damper', that round rubbery 'hockey puck' looking thing on my passenger side drive axle. While my car is in parts, I am cleaning and fixing everything, including the drive axles. The RH Drive Axle 'damper' (if that is the correct term) is clearly broken. ![]() Can anyone tell me the correct name of, and function of, this part of the axle? Also, when I looked up replacement axles on Rock Auto, none of the RH axles had that part attached, so I am wondering if I need to find an exact replacement. OR. . . is there any way to replace just that part? BTW: I DID search, as best I could, for information already posted, but called a halt to my searching after expending several hours reading. I also looked through my Haynes and BGB resources without luck, although there are times I fail to find something that I later on, do find in those books. I apologize in advance if I should have been able to find this information. |
That has broken free on a couple of my axles. I just ripped it off and kept driving, never had any unwanted vibration.
Thanks, Richee3, If I whack it off and keep using that axle when I put it all back together and the car drives ok, then it is good advice cause it saves me $.
But do you know what it was designed to do for the axle, or car, and what it's correct name is? You used the term 'vibration', and I had previously introduced the term 'damper', but I want to pin this down precisely so I feel confident about what I think I know. I am learning much from tearing my engine down; my curiosity seems endless, as does this job that others claim to do in a day or so. |
Lo-Fi Version | Time is now: February 18th, 2025 - 3:01 PM |
