Lights on my shifter (At) wont light up, why not? |
Feb 22, 2004 - 11:53 PM |
Enthusiast Joined Feb 3, '03 From Maryland Currently Offline Reputation: 0 (0%) |
My automatic lights (P, R, D, 2, L) arent lighting up, anyone know wut might cause this? and how to fix it
Feb 23, 2004 - 12:02 AM |
Enthusiast Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) |
I don't have an auto so I'm just guessing that your bulbs must have burnt out or something. More than likely the have to be removed and soldered back in. But you can always check your fuses to make sure you didn't blow one.
Feb 23, 2004 - 7:53 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
doubt its the fuse, because if those don't work your gauges or heater and A/c lights shouldn't work either.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Feb 23, 2004 - 8:32 AM |
i dont think they use LEDs, not 100% but its probably 1 or 2 bulbs.
Feb 23, 2004 - 8:39 PM |
Enthusiast Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
dude i had the same problem not to long ago. Mine would go out and then come back on every once in a while. They finally started working all the time but i use to have to knock on the side of the trany pannel.
-------------------- hows it taste motha f*cka
Feb 25, 2004 - 8:08 PM |
Enthusiast Joined Nov 8, '02 From Narragansett,RI Currently Offline Reputation: 0 (0%) |
The same thing happened to mine, but I just left mine alone. It's not that big of a deal to me and it doesn't seem like it would be a simple fix.
Feb 25, 2004 - 8:11 PM |
Enthusiast Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
Same happened to my previous car. As long as you dont have to look down to shift, then it's ok.
Feb 25, 2004 - 8:37 PM |
same thing happened to me ... i was have to slap the side of the shifter and it would come back on.. now it just stays on all the time..
Dec 24, 2005 - 2:46 PM |
Enthusiast Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Bringing this post back from the dead. I am having the same problem too. I would imagine you have to replace one or two bulbs and take the center console out and sh*t...what a pain. Can anyone give a brief how-to? I guess I'll just try to slap my console or shifter around for now.
This post has been edited by Celicav: Dec 24, 2005 - 2:46 PM |
Dec 25, 2005 - 1:42 AM |
Enthusiast Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) |
hmm. a while back i replaced mine with a single blue num74 led. it had to have the nose of it filed down quite a bit before it would fit in there. then after a couple of weeks it started going out after the car had been on for a while (defective num74 fabrication (resistor) i guess). replaced it with another and has been fine since, can't see the R light very well though.
i think the second time i did the mod i didn't remove the led from it's base, just filed it down more than the time before. wrote up a little mini-howto back when i did the mod. it's not a difficult mod. but does involve the painful task of cleaning your center console ///////////////////////////// // How-To Tools: phillips-head screwdriver, 12mm socket wrench (either a small wrench or an extension for it), needlenose pliers, bastard file, x-acto knife Parts: 1x num 74 led (http://autolumination.com/74.htm) ///////////////////////////// // Disasembly 01. Turn car on 02. Put the handbreak on 03. Put the car in neutral 04. Pull off the plastic panel from around the gearshift (just 4 clips holding it on) and let it hang to the side. 05. Put car back in park 06. Turn car off 07. Use socket wrench to unscrew 2 bolts inside center console compartment 08. Unscrew 2 small screws on center console right where it meets the gearshift 09. Pull center console up a little bit 10. Unfasten ashtray/change light wiring harness 11. Pull center console the rest of the way off 12. Unscrew 2 small screws (these were copper for me) at the front and back of the automatic gearshift indicator. The one at the back is hard to get at, but you should be able to fit your screw-driver down the gap. 13. Pull the cover of auto-gearshift upwards till it flops around the shift handle. 14. Twist out small (green for me) wire from driver side of auto-gearshift 15. Pull the bulb out of this little wired socket ///////////////////////////// // The num74 LED - The one i used was too big to actually fit so 01. Bend led legs backwars until they point straight down 02. Grab led lens with needle-nose pliers and pull base off with fingers 03. Grab base with pliers and file off about 2mm from the top and the bottom. 04. Clean excess plastic off with x-acto knife 05. Re-insert led into base 06. Bend LED legs back into place 07. Grab led by the bottom of its lens with needle-nose and file down the top of the lense (2-3mm). *don't* file into the actual diode 08. Insert led into wired socket 09. Turn lights on (if led doesn't light turn lights off, rotate led 180 degrees and try again). 10. Twist wired socket back into place. 11. Test lights again before re-assembling (keep in mind you won't see much in broad daylight). This post has been edited by Zimluura: Dec 25, 2005 - 1:45 AM |
Dec 25, 2005 - 4:45 PM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
While on this topic, how hard do you think it would be to change the font of the letters
Lo-Fi Version | Time is now: November 30th, 2024 - 6:15 AM |
