> Can't get car to crank
post Aug 7, 2017 - 6:36 PM
T3naci0usT
Joined Apr 25, '17
From Texas
Car has a new battery new starter, and new fuses for relay and EFI. Still won't start.
Story time,
So my water pump went out and as I was pulling in to park the car so I could tow it. It won't start anymore. The engine isn't locked up, and I can't figure it out for the life of me.
Any help would be awesome.
post Aug 8, 2017 - 3:08 PM
T3naci0usT
Joined Apr 25, '17
From Texas
Also the only thing I haven't changed is the clutch safety, but whenever I was pulling the car in it sounded like the starter was losing power, and then wouldn't start anymore.
post Aug 10, 2017 - 5:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
You can bypass the clutch safety switch to make sure that's not it before replacing it. I'd check all your grounds, relay, and ignition switch.
2001 Miata LS 5-speed
post Aug 10, 2017 - 6:47 PM
T3naci0usT
Joined Apr 25, '17
From Texas
I am thinking a ground issue.
Anyone mind taking a picture of the negative battery terminal connections.
post Aug 11, 2017 - 2:10 PM
T3naci0usT
Joined Apr 25, '17
From Texas
Well I took apart the passenger side ground and it smelled like burnt electrical, so I am going to guess that is my problem.
post Aug 11, 2017 - 7:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
I would take pics if I still had one, but sounds like you may've found it hopefully.
post Aug 16, 2017 - 3:09 PM
T3naci0usT
Joined Apr 25, '17
From Texas
So that didn't fix the issue. it like freaks out. whenever I go to turn on the car both fans immediately kick on, and the temp sensor goes all the way to the top. Even though the car hasn't ran in over a week. Also whenever i turn it off some of the lights stay on. Any suggestions?
post Aug 17, 2017 - 9:09 AM
richee3
Joined Jun 29, '08
From Denver
That’s definitely a ground issue somewhere. Grounds can cause some weird issues to happen. You may go ahead and try the Big Three upgrade just to cover your bases.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 17, 2017 - 2:13 PM
T3naci0usT
Joined Apr 25, '17
From Texas
What is the big three upgrade? Also can you buy a ground cable for the battery terminal of our cars I might need a new one.
I have replaced the battery, starter, and fuses. The ground on the passenger side has been replaced, and only thing I haven't replaced is negative battery connection, and the key starter.
Also the last time the car started it sounded like it wasn't getting power.
post Aug 17, 2017 - 8:28 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
so the engine cranks over but it doesnt start?
pull a spark plug, stick it in the wire and crank it over. is it sparking? if no then you have a problem in the DIZZY or crank position sensor.
if it does spark you might have a fuel issue
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 19, 2017 - 10:10 AM
T3naci0usT
Joined Apr 25, '17
From Texas
No crank what so ever.
post Aug 20, 2017 - 9:14 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Not even a clunk or click from the starter? Get a test light and verify power to the smaller starter wire (solenoid wire).
post Aug 20, 2017 - 12:18 PM
T3naci0usT
Joined Apr 25, '17
From Texas
Yeah I was going to do that, or get a multimeter and make sure it is getting the correct voltage.
post Aug 27, 2017 - 9:54 PM
T3naci0usT
Joined Apr 25, '17
From Texas
I GOT THE DAMN THING STARTED. Redid the grounds and it started right up.
Lo-Fi Version Time is now: November 26th, 2024 - 1:20 PM
