13 Pages V  « < 6 7 8 9 10 > »
> Freelica, $0.00, new trans, new life
post Jul 26, 2018 - 3:46 AM
Box
Joined Feb 23, '12
From Warrior, AL
If Toyota gearboxes are like Nissan gearboxes then there are bolts in the casing that hold detente springs and balls for the gear selector rods, bolts one could mistakenly remove instead of the drain plug if they don't know what they're doing. If that were the case would explain why it won't go into gear and the clunking when you let the clutch out. Should be able to open the case and see if a rod is out of place at least, though who knows on finding replacement detente springs and balls. That or just the selector itself could be messed up in general.
2001 Miata LS 5-speed
post Mar 4, 2019 - 10:38 AM
cheela
Joined Feb 2, '07
From Berlin, WI
well Freelica's got a trans finally...
Only it's still connected to another blue celi so we'll have to work that out somehow. Thanks to Jake & Sam for dropping it off and also taking something else off my hands at the same time. wink.gif
post Mar 4, 2019 - 2:04 PM
TimeslideZ
Joined Jun 9, '16
From Minnesota
Dude that blue one actually seems pretty clean overall.... You should give it to me for free so I can start another Freelica thread.
This post has been edited by TimeslideZ: Mar 4, 2019 - 2:04 PM
post Mar 4, 2019 - 2:11 PM
cheela
Joined Feb 2, '07
From Berlin, WI
It's pretty rusty too. midwest cars... lol It got repainted and the blue looks awesome but the body isn't. But it's a blown 7a with a good trans and that's what I need. I might swap the hood and fenders to Freelica since it seems like Freelica's hood flew up as one point in it's life and has damaged the hood and fenders.
post Mar 4, 2019 - 8:30 PM
Car killer thread for sure
Is the castle nut available?
post Mar 5, 2019 - 12:03 PM
cheela
Joined Feb 2, '07
From Berlin, WI
lol. I'm going to revive Freelica. have some faith..... .. ..
I'm only taking the trans and a few body panels so everything else should be up for grabs.
post May 10, 2019 - 1:57 PM
cheela
Joined Feb 2, '07
From Berlin, WI
swapped hoods a while back because the black hood was junk so it might as well go on the junk car.
then pulled the blue celi into position to get ready to drop the trans. stripped the interior and bumper, lights etc.
would be nice if I could do this in the garage but the green BEANS is currently taking up the entire garage so that's a no go.
car port will have to do for now. it's just a trans swap anyways.
BEANS or Freelica, one and/or both of these will run!!!! laugh.gif
post May 10, 2019 - 2:46 PM
Box
Joined Feb 23, '12
From Warrior, AL
You can doooo itttt!
post May 13, 2019 - 9:32 AM
ngrome
Joined Oct 14, '18
From Chicago, IL
So if you get a rusty Celica, is it called a Rustica? Sounds like something you can order at Olive Garden. biggrin.gif Thanks you ladies and gentlemen, I'll be here all week...
post May 20, 2019 - 8:17 AM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (ngrome @ May 13, 2019 - 9:32 AM) *
laugh.gif laugh.gif well this one is pretty rusty already but I chose the name Freelica over Rustlica. lol
post Aug 7, 2019 - 10:30 PM
cheela
Joined Feb 2, '07
From Berlin, WI
Been a while since I've updated this.
I'm slowly breaking the blue car for parts. Some/most will be up for grabs. Others will be put on Freelica.
bumper, fender, door mirrors, lights, turn signals etc taken off.
Interior is stripped nearly. Need a couple more bolts to take out the dash.
rear lights and spoiler too. might as well take the trunk. lol
draining fluids to take out the trans.
So we get to today. Today I decided to work on the blue car and get the trans out of the way. Everything went smoothly. All bolts came out and were easy to loosen. Kept the driver's side axle in because I'm probably going to use it. about an hour or less into it and the trans, clutch, and flywheel are off. yay! now to just bolt it onto Freelica and I'll have ONE running celi. biggrin.gif
You can say I was feeling pretty good but then once again mother nature intervene with a big F U. Brought in the rain so I quickly cleaned up and went inside only to watch the wind pick up, and the torrential downpour turn into a full on hailstorm. a hailstorm in august!? come on, the one day I work on cars and this happens. I think the car gods are not happy with me. laugh.gif
post Aug 7, 2019 - 11:21 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Send me the double din radio panel and the fog light connector with pigtails, plz. kthx.
-Alex {](O_o)[}
post Aug 8, 2019 - 7:34 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
You should've put your chainmail and a snorkel on, and kept working. It would have been fine.
~bloodMoney
post Aug 8, 2019 - 8:44 AM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (NgoFcukinWay @ Aug 7, 2019 - 11:21 PM) *
I think it's a double din. I'll have to check. and sorry, it's a 94 so no fog lights
QUOTE (bloodMoney @ Aug 8, 2019 - 7:34 AM) *
I would've if it wasn't for the lightning. I don't mind being pelted with hail but death by lightning doesn't sound that fun. lol
post Aug 8, 2019 - 10:41 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Yea... Despite your comments in the TOTD thread, I don't want you struck by lighting, so you made the right choice.
~bloodMoney
post Aug 8, 2019 - 2:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
See but if you get struck by lightning and live there's no better time to buy a lottery ticket.
post Aug 8, 2019 - 2:28 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (bloodMoney @ Aug 8, 2019 - 10:41 AM) *
QUOTE (Box @ Aug 8, 2019 - 2:20 PM) *
hmm... Idk if I would consider that good luck or not. also, have you seen my green BEANS thread? I am not having the best of luck there. laugh.gif
post Aug 10, 2019 - 10:12 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (cheela @ Aug 8, 2019 - 2:28 PM) *
Seriously, do I need to come help? I came out and had the brakes on Lindsay's 7th gen up and going in like...a day after it sat up for a year because of brakes.
post Aug 10, 2019 - 5:26 PM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
Chee accept the help.
post Aug 10, 2019 - 6:03 PM
Bitter
Joined Mar 11, '06
Will work for food and can sleep anywhere.
Lo-Fi Version Time is now: November 27th, 2024 - 1:10 AM
