1994 celica want spin over |
Nov 9, 2017 - 6:55 PM |
Enthusiast Joined Nov 9, '17 From texas Currently Offline Reputation: 0 (0%) |
So I got in my car to leave and I pushed the clutch in and hit the switch and it turned over a few times and stopped .But it still has power . Where do I go
from here ? |
Nov 9, 2017 - 10:09 PM |
Battery could be weak, check it with a voltmeter.
Nov 9, 2017 - 11:33 PM |
Nov 10, 2017 - 11:43 AM |
any one know how to check the safety switch on the clutch on my 1994 celica
Nov 10, 2017 - 5:49 PM |
You can pull the connector off the switch and jumper it with a piece of wire.
Nov 10, 2017 - 6:36 PM |
that was not it I bypassed the clutch switch
also it keeps popping the am2 fuse |
Nov 11, 2017 - 1:52 AM |
You have a short in the ignition system somewhere then if it keeps blowing the AM2 fuse.
Nov 13, 2017 - 1:32 PM |
ok guys that was it my resistor is bad. So I changed it started it up and the coil went bad ? this is the fourth coil in three years ant one know why they would go bad so often
Nov 13, 2017 - 11:28 PM |
Have you ever replaced the ignition coil cable? A bad cable can cause too much strain on the coil and burn it out.
Lo-Fi Version | Time is now: November 24th, 2024 - 12:47 AM |
