Enthusiast Joined Oct 30, '16 From SoCal Currently Offline Reputation: 1 (100%) ![]() |
The ABS light never comes on on my '99 liftback. I checked near the power steering reservoir and I found that box with all the brake lines so I'm almost certain the car has it. The dealer manual says if you connect 2 pins on the diagnostic port it would blink. I did that and only the SRS and Cruise lights blinked. Could it be the light is burned out or something?
It's possible the bulb is out. If is has the ABS module I'd check the bulb, then any related fuses and relays. Of course it's really easy to test if it's working or not, just slam on the brakes and see if it locks up or if the car pulses the brakes for you.
Lo-Fi Version | Time is now: April 22nd, 2025 - 1:17 AM |
