15 Pages V  « < 12 13 14 15 >
> '98 Celica GT: The Continuation...., Dun dun duuuunnnnnn.....
post Oct 17, 2020 - 6:22 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (Bitter @ Oct 17, 2020 - 5:37 PM) *
Should you drop the oil pan and check the oil pickup screen for blockage or the pan for poor clearance to the oil pickup?
did that a while ago and the pick up is clean. pan is undamaged, so there shouldn't be clearance issues. I think i'll order a new pick-up gasket from toyota and see if that fixes things.
-Alex {](O_o)[}
post Oct 17, 2020 - 6:29 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
The old school trick is to prime the pump with thick assembly lube oil or just thick (20W-50) engine oil and pre-fill the filter then cross your fingers it all works right. Usually if the pump isn't sucking there's a reason, like worn pump or excessive pump clearances that's causing low suction and it'll still be a problem once it's running and hot.
post Oct 18, 2020 - 5:31 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
WE HAVE OIL PRESSURE!!
I've no idea what the **** it was that I did, but oil is flowing again. Essentially primed the pump with oil to test how the gear is working, slapped it on the block, ugga dugga the oil pick up to the pump, slapped the oil pan on, filled with break-in oil, disconnected the turbo oil feed line, and spun the oil pump gear and it started to bleed out. Plugged that line back and then pulled off the oil pressure gauge and spun the gear again to confirm. Oil bled out of there as well as did the oil filter.
Now I just gotta put this **** all back together again. I am not looking forward to that.
-Alex {](O_o)[}
post Oct 18, 2020 - 9:15 PM
Bitter
Joined Mar 11, '06
Finally, someone with some good news!
post Oct 24, 2020 - 1:13 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
SitRep: Oil pan is officially resealed and bolted back to the block. Filled the motor with some Amsoil Engine Break-in oil and tested the pump again just to ensure it wasn't a fluke when I tested it before. Currently fighting the timing belt to get it back on, but I think I've picked up a trick to get it on based on some videos i've seen.
I guess tune in tomorrow to see what happens.
-Alex {](O_o)[}
post Oct 25, 2020 - 9:31 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Ok. got the timing belt on and now to put everything else back on....
-Alex {](O_o)[}
post Oct 26, 2020 - 7:03 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
So.... Is is running yet?
~bloodMoney
post Oct 26, 2020 - 8:17 PM
cheela
Joined Feb 2, '07
From Berlin, WI
^that.
post Oct 26, 2020 - 8:28 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
^this.
-Alex {](O_o)[}
post Nov 2, 2020 - 12:01 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
got lazy yesterday and didn't do anything except binge season 7 of Agents of SHIELD.
Today, put some time into the car and got the lower timing cover on along with the AC belt and the motor mount. Just need to tighten down the tensioner for the power steering pump and I think I can attempt to start the car again...maybe...
-Alex {](O_o)[}
post Nov 2, 2020 - 8:52 AM
Bitter
Joined Mar 11, '06
QUOTE (NgoFcukinWay @ Nov 1, 2020 - 11:01 PM) *
laugh.gif That's A LOT of show.
post Nov 2, 2020 - 8:54 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
if it makes it any better, i started the first 6 episodes friday night and then finished the last 7 on Saturday. lol
-Alex {](O_o)[}
post Dec 6, 2020 - 1:28 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Over Turkey Day weekend, some friends came over to help out and double check to make sure timing belt and crank was all lined up properly. Still no dice.
however, i did notice that the pins for power and ground for the oil pressure and fuel pressures sensors were flipped on their connectors. Corrected them and then started to fiddle with the analog input in the PCLink software and managed to pick up Oil Pressure on Analog 4, so making some progress.
My IAT is still reading -40C for whatever reason. Aaron is saying that's because there's a bad connection somewhere. Part of me thinks I just have the 2 wires swapped out. I'll fiddle with it some more tomorrow when I have time.
-Alex {](O_o)[}
post Dec 29, 2020 - 8:19 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
ummmm..... ahem....
Got IAT, Fuel pressure, Oil Pressure, wideband, and Flex fuel to read correctly after Scott sent me how he wired up the auxiliary harness.
car still won't crank, so I guess we'll continue to look into that... :\
-Alex {](O_o)[}
post Dec 30, 2020 - 8:59 AM
Bitter
Joined Mar 11, '06
No crank as in the starter isn't working?
post Jan 10, 2021 - 10:28 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Starter works and all that.
What's a good website to host videos that this forum will accept?
-Alex {](O_o)[}
post Jan 11, 2021 - 8:47 AM
Bitter
Joined Mar 11, '06
Youtube?
post Jan 11, 2021 - 4:46 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
I saw your video Alex.
If the ECU is firing the plugs right, then your only real remaining avenue is fuel. Your wideband was showing 14-16, wasn't it?
Will is start on starting fluid?
~bloodMoney
post Jan 23, 2021 - 11:53 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
3S no start
Here's a video of it coughing.
I just set the timing to 0 via the standalone and confirmed with the timing light and still not getting anywhere.
-Alex {](O_o)[}
post Jan 25, 2021 - 2:45 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
Have you done a compression test?
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 5:18 AM
