Multiple questions thanks in advance |
Dec 11, 2017 - 6:44 PM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
Straight forward I have a couple questions answer if possible thanks guys
1. I’m about to replace the passenger Cv axle I’ve never done a transmission flush will doing so now After 204,000 miles be bad is it ok to replace oil ? 2. What could trigger the car to have a shaky idle randomly When I stop at a light it only happens sometimes steady rpm and out of no where it drops like it wants to shut off 3 is it normal ? I took out my spark plugs to see overall health and they are white/ grayish tip With tip still being like new changed 10k miles ago Thanks for the help |
Dec 12, 2017 - 12:08 PM |
Enthusiast Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
You'll need to drain the trans to replace the axle anyway. Otherwise, once you pop the axle out, all the oil will come out with it.
When was the last tune up? Cap, Rotor, Wires? If you replaced the plugs 10k ago, grey coloration is normal. -------------------- ~bloodMoney
Dec 12, 2017 - 12:20 PM |
Enthusiast Joined Sep 1, '09 From Marengo, IL Currently Offline Reputation: 0 (0%) |
You almost never want to "flush" your trans at a shop, especially with high mileage. You'll want to just drain in your garage and refill. Do that for the next few engine oil change intervals and you'll be good for a while (probably the life of the car/trans/engine) IMO.
-------------------- 2000 GT-S 6 SPD... SOLD! |
Lo-Fi Version | Time is now: November 26th, 2024 - 5:05 PM |
