> Transmission doesnt engage at low rpm, any advice will help
post Jan 24, 2018 - 2:33 PM
rapid36
Joined Feb 5, '13
Hello everyone my celica has been running great for years after my rebuild and i always had a running rich check engine light. I recently now am having troubles sometimes but NOT ALWAYS engaging into a gear from either a dead stop and trying to go again or shifting into a new gear. Seems like when im going and driving it doesnt have any issues going into any gears but from a dead stop it sometimes wont get into the gear unless I rev up to about 1.5k-2k super embarassing at stop lights as you can imagine. Any advice would be appreciated. Let me know what you guys think that I can start checking.
Things I have checked.
Transmission fluid is full and havent had to add any.
No new check engine lights or codes.
Thanks for your time!
post Jan 24, 2018 - 3:26 PM
Box
Joined Feb 23, '12
From Warrior, AL
How many miles has it been since the rebuild? Supposed to change the fluid and filter every 25,000 miles or so.
2001 Miata LS 5-speed
post Jan 24, 2018 - 4:15 PM
rapid36
Joined Feb 5, '13
QUOTE (Box @ Jan 24, 2018 - 3:26 PM) *
Its been 15k miles since the rebuild. Its probably close to that time then smile.gif. Could give that a try thank you! Also where is the filter? Are you just referring to the magnets in the transmission oil pan?
post Jan 24, 2018 - 6:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
Most automatics have a metal and mesh/foam filter that goes into the valve body. Which if it was rebuilt it's possible they didn't get the clutch friction spacing right and it's burning itself up... Check the fluid for grit or burnt smell. You might want to contact the rebuilder if there's a warranty it's still within and voice concern. It's also possible that solenoids or something in the valve body is sticking. This is why I don't like automatics, they're full of black magic.
post Jan 24, 2018 - 8:43 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
I think the OP has a manual? if you cant shift into gears while stopped and the engine is running, your clutch is toast.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 24, 2018 - 9:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Under their profile pics it had an automatic, unless this is a different car and they didn't update it.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:39 AM
