> ST205, could I change pistons in situ?
post Mar 20, 2018 - 5:20 AM
Riikan
Joined Nov 15, '17
From Bangkok
I'm planning change the head gasket & studs on next holiday, want take this chance also to press some arp conrod bolts / check condition of bearings.
Currently not enough space to drop another engine. All car I previously worked on could change pistons from under car no problem, but the Celica seems pretty cramped at bottom. Wonder do I have enough clearance to remove the : upper half oil pan, retrieve piston #4 , while the center beam still there?
Is the oil pan tricky to remove?
Thanks for any input!
Lo-Fi Version Time is now: November 23rd, 2024 - 12:00 PM
