Project: I dunno yet ('99 GT), NOW with pictures & video [IN COLOR]! (Update BOTTOM of pg.5) |
Jul 15, 2022 - 6:39 PM |
Enthusiast Joined Aug 17, '09 From Millard, Omaha, Nebraska Currently Offline Reputation: 1 (100%) |
I really appreciate the offer but I'm going to have to decline it. Mental capacity to want to have a project is basically none.
Aug 1, 2022 - 10:59 PM |
On Friday I had to replace the right side washer nozzle because the barb the the hose pushes onto had turned to crumbly bits. Also blew out the left side. Both nozzles work good now.
The driver's door was really squeaky when opening/ closing it, so I sprayed it down. Sounds stupid but I washed/ cleaned/ took steel wool to the car key. It was pretty discussing & that's one thing I didn't clean when I bought the car. Going back to the major issue I had... I swear I still can feel some kind of RPM fluctuation while driving, although its not to noticable. And a few times since I've put the crank sensor in it's had an extended crank but fires right up. Not to worried about it as long as the car don't let me down on a road trip, LOL. |
Aug 3, 2022 - 9:38 PM |
Needs new muffler bearings.
Aug 4, 2022 - 11:20 PM |
I wouldn't doubt it.
Sep 20, 2022 - 7:59 PM |
Had to change out some brake light fluid. Didn't make mess, so that made me happy.
Jan 8, 2023 - 8:13 PM |
Really wanted to drive the Celica the past few days but the roads are still covered in salt & potholes. Even tho the car isn't perfect would still like to keep it clean. Maybe I'm using that as a excuse, LOL.
Jan 13, 2023 - 10:51 PM |
Same man, same. We keep having a few scattered 50 or 60 degree days but they're bracketed by rain/snow/freezing temps so everything is salted so bad it's like driving around on gravel roads in some places.
Feb 4, 2023 - 1:01 AM |
Facebook reminded me... February 3rd/ 4th 2018 is 5year anniversary. Exciting I know.
I might pull it out of the garage since it's supposed to be warm & drive it around. If I remember how to drive a manual, lol. Been sitting since mid-December with a battery tendy on it. This post has been edited by navseal345: Feb 4, 2023 - 1:02 AM |
Feb 5, 2023 - 1:04 AM |
Almost warm enough here, 40 degrees. Roads however are so salted much that my Mazda can do burnouts from stop signs on the powdered road salt.
Feb 6, 2023 - 4:52 PM |
Enthusiast Joined Jun 9, '16 From Minnesota Currently Offline Reputation: 0 (0%) |
Don't do it, the salt be too much. We're about to jump back up to 40's for two days then drop again in MN. Snow and ice is still there.
Feb 6, 2023 - 7:38 PM |
To late. Drive it to work today & I'll probably do it tomorrow & Wednesday.
Feb 10, 2023 - 6:46 PM |
I can hear it rusting in my nightmares now, thanks!
Feb 10, 2023 - 7:43 PM |
Well it is parked next to my truck that's a rusty POS.
Feb 11, 2023 - 4:48 PM |
Bed sides over the wheels and the cab rocker panels? How they constructed those flares over the wheels on the bed is just ludicrously stupid, the layers of steel are almost built to rust out. I've seen some people drill big holes into them and paint the insides but leave the holes open so they can drain out and get washed out regularly.
Feb 11, 2023 - 8:13 PM |
Rocker panels are the worst. Bed is in ok shape.
Feb 11, 2023 - 9:50 PM |
For as much and as often as rocker panels rot on cars you'd think we'd have advanced to the point that they'd be bolt on or plastic.
Feb 11, 2023 - 11:22 PM |
I'll be interesting on all these aluminum cars in a few years.
Aug 13, 2023 - 6:14 PM |
So... Had a P0115 (Engine Coolant Temperature Sensor 1 Circuit) pop up, So that's just dandy.
At least for now I have another POS to drive. |
Sep 9, 2023 - 4:14 PM |
Finally got around to fixing the Celica. Ended up being the coolant temp. sensor for the ECU. Unplugged it & ECU read -40°, then jumped the connector & it read 284,°. Also put an ohm meter on the old sensor & nothing.
I swear this is the sweet spot year for cars. Most of the time super simple to diagnose. Also tightened up the cruise control cable. It would accel & decel like maybe 4mph from set speed. Hope that fixes it & I didn't f*ck it up. I think that's all for now. |
Sep 20, 2023 - 11:21 PM |
Hell yeah, I hope that's it. Gotta get back out this way to see the Bison over at Buffalo Rock across the river.
This post has been edited by Bitter: Sep 20, 2023 - 11:21 PM -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 1:19 PM |
